Old 01-11-2017, 10:56 AM   #57
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Originally Posted by LesBaer View Post
BTW - here are the weights on the Hellwig parts...looks like you save a few pounds.
Front - Part #55719 -18.6lbs
Rear - Part #55819 - 15.8lbs
That was quick!
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 01-11-2017, 10:59 AM   #58
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Yeah he didn't waste anytime in getting back to me LOL. I just shot Ted an email to ask him for his 2 cents. I think BMR might make them as well. I need to stay away from this board...it causes me to buy things!
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 01-11-2017, 11:04 AM   #59
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
Originally Posted by LibertyHill View Post
I assume the ZL1 arms are the same as SS OE, and with the track times that heavier car has put down why bother?
The ZL1 trailing arms are a different part number. The arm itself is the same, but the bushings are significantly stiffer.
rotis is offline   Reply With Quote
Old 01-11-2017, 11:05 AM   #60
LibertyHill
Let us know what he says!
Old 01-11-2017, 11:33 AM   #61
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Definitely, will do...he should be finishing up my cam job any day now
Old 01-12-2017, 10:23 PM   #62
Mountain
Mountain's Avatar
I just ordered a FE4 (1LE/ZL1)front sway bar. I'll measure the blade thickness to derive a rough wall thickness.
Old 01-13-2017, 10:47 AM   #63
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I'm just going to go with the full 1LE suspension upgrade now. I want the MRC tuning adjustment and with the amount of power my car is going to be making now (I have 2 55g barrels of E85 being delivered today ), I'm not really worried about a few extra pounds anymore on the sway bars.
Old 01-13-2017, 01:25 PM   #64
Mountain
Mountain's Avatar
I got the sway bar today. I measured the attachment blade thickness... What I got equals basically the same wall thickness of the SS bar, which is said to be 0.156". The part number I have is 84052981. Can someone confirm their part number? Maybe this is not a good way to check the wall thickness (i.e. the blade is compressed enough in manufacturing to where it disrupts the wall thickness). I'm going to double-check the diameter.
Old 01-13-2017, 01:34 PM   #65
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I think diameter is going to give you better comparison between bars, no?
Old 01-13-2017, 02:07 PM   #66
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I don't even know if your diameter is going to matter. Each bar has different torsion specs, which is basically how much it's going to flex.
Old 01-13-2017, 02:08 PM   #67
Mr. Wyndham
Correct. But typically, they achieve these torsion specs with diameter...
Old 01-13-2017, 02:20 PM   #68
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
You need both the diameter and the wall thickness.
Stiffness for a tube is roughly a function of diameter (cubed) times wall thickness.
More precisely, it's a function of outside diameter to the fourth power minus the fourth power of the diameter of the hole down the middle of it.
But wall thickness is generally easier to measure in cases like this.
Norm
Old 01-13-2017, 05:25 PM   #69
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Norm
its a legit blessing you are on this forum with the tech and help. seriously!
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 01-13-2017, 05:26 PM   #70
Mountain
Mountain's Avatar
Contrary to what's listed here, the front bar I bought is 30.3mm or 1.19", NOT 28mm or 1.10".
