Old 12-15-2016, 09:17 PM   #57
08z51c6
Drives: 2016 Camaro SS - A8, MRC, NPP
It can void the warranty.
It does not mean they will void your warranty/refuse to repair the vehicle.
Especially if the failure is a known issue they should do you right.
My 2014 Silverado spun a rod bearing. at 28k miles. It has a tune, headers and cai. They knew damn well that didn't cause the bearing failure
Full replacement motor no questions asked. Free towing and a rental.
But one should assume the risk when tuning. Not everyone will get so lucky.
I guess one could argue the fact that they have trucks from the factory that are Flex Fuel but my dealer is anal about modifications, especially if they didn't install them.
Delivered: 2016 SS Nightfall Grey - 1SS, MRC, NPP, A8
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
08z51c6 is offline   Reply With Quote
Old 12-17-2016, 10:41 PM   #58
EFI Tuning
EFI Tuning's Avatar
Originally Posted by moonrider View Post
I got my kit yesterday now I need to find time to install and find a place close by to get it tuned. Hey Tim do you have instructions for the install?
I created a new thread for the install guide. It is very rough right now but I will be getting it completed over the next few days. I am finally caught up on orders
Tim
EFI Tuning is offline   Reply With Quote
Old 12-18-2016, 09:14 PM   #59
moonrider
Drives: 2016 2SS
Thanks! Can't wait to be on E85, but I might have to wait until spring 😭
moonrider is offline   Reply With Quote
Old 12-20-2016, 01:45 PM   #60
jayb998
jayb998's Avatar
Drives: 2016 2SS M6
i have a heads/cam long tube car would i still see the same 30-40hp gains on top of the parts already installed
jayb998 is offline   Reply With Quote
Old 12-20-2016, 02:09 PM   #61
EFI Tuning
EFI Tuning's Avatar
I do not have any results for a H/C car yet. I believe the gains will be comparable. HOWEVER, the real issue to focus on is the fuel system. Do you happen to have logs from your car showing injector pulse widths during a WOT dyno pull?
Feel free to give me a call if you want to discuss in detail.
Thank you,
Tim
Old 12-20-2016, 02:10 PM   #62
ULTRAZLS1
ULTRAZLS1's Avatar
You should. Even more if you raised the compression from stock with milling or thinner head gaskets. Higher the compression the bigger the gains from e85.
I don't think the stock fuel system will support a heads/cam e85 car but just guessing.
Old 12-20-2016, 02:12 PM   #63
ULTRAZLS1
ULTRAZLS1's Avatar
Thank you,
Tim
How much does the additional 30% fuel lobe available on some cams help with the fueling issue? Guessing not much on its own?
Old 12-20-2016, 02:14 PM   #64
EFI Tuning
EFI Tuning's Avatar
It will help some. Obtaining some logs with the injector pulse width data will tell me how much margin is left across the RPM band. I suspect LT4 high side pump/injectors will be needed.
I would really love to be able to offer a fuel setup for H/C with E85 or N20 with E85 that won't break the bank. There just aren't many setups out there right now to collect data from. This should change in the next few months.
Tim
Old 12-20-2016, 03:00 PM   #65
parish8
Drives: 17 SS a8
I am at 450rwhp and 5ms and for an experiment I added 20% fuel to 6ms and it pushed my a/f from about 13/1 down to 10.2/1. The pressures all held. I think the stock set up would do at least 540rwhp on e85.
How much power will a heads cam motor make? Add in a zl1 in tank pump for under $200 and the larger lobe on the cam and I would bet the fuel system would go to 600na on e85.
