Old 12-29-2016, 09:15 AM   #57
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by steelheadrob View Post
For a first time SC car guy this is great info. I saw early on this thread Ted preferred non intercooled with the meth kit up to 10 psi. This is the direction I am leaning. Might consider the intercooled version, trying to understand what the extra $1,900 gives me over the non intercooled/meth kit combo from a psi/hp/tq standpoint.
Water Meth injection has its limitations, inherent problems,routine maintenance, and possible failures.
Where an inter-cooled system is a permanent solution that requires no maintenance is it as reliable as the rest of the car.
What I said is Non inter-cooled systems will benefit more from Water/Meth injection than an inter-cooled system..
One of the worries about running water/meth is having enough temp to vaporize the liquid being injected.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-29-2016, 11:23 AM   #58
Speedy1975
FASTER!
^^ Exactly.
If buying a modern supercharger system, I would never recommend a non-intercooled unit if intercooled is available. I'm surprised it's even an option to be honest.
Old 12-29-2016, 01:05 PM   #59
JANNETTYRACING
Originally Posted by Speedy1975 View Post
^^ Exactly.
It does give a guy on a tight budget a way to get in to a super high quality supercharger system rather than purchase something smaller or cheaper and not of as high quality that he may regret later.
Then as budget allows they can add the intercooler kit to the supercharger at a later date.
Ted.
Old 12-29-2016, 07:17 PM   #60
laynlo15
Drives: 2022 Lt1 A10
I'm sure Ted is right, he's been at this a long time and his reputation is up there. I may end up doing the intercooler next year sometime.
Old 12-30-2016, 10:08 AM   #61
steelheadrob
Tactical Garage
steelheadrob's Avatar
Always good to have options. In the end I might just go intercooled up front. Problem is not matter which direction I go, I going to want to spend money on some other upgrade 6 months later.
For now I will stay tuned to see how laynlo's nonintercooled/meth build turns out.
steelheadrob is offline   Reply With Quote
Old 12-30-2016, 12:42 PM   #62
Speedy1975
FASTER!
Based on my experience, I definitely would get the intercooler when you have the cash for it.
Old 12-30-2016, 08:50 PM   #63
JoeAyalaM
Drives: Audi S6 V8TT, Volvos XC60 & S60R
I concurr that it is a no brainer if you are going for Street and/or Drag use, for road course use, may be really good drivers will notice the weight difference up front.
JoeAyalaM is offline   Reply With Quote
Old 12-30-2016, 09:20 PM   #64
toohighpsi
Drives: 2015 C7 Z06 M7
As you might guess, I have driven both systems extensively, even at ambient temperatures of 105F the non intercooled kit really runs well on the DI engines. With a max of 5.5 psi of boost the IAT generally hit a peak of about 150F when running hard and any restriction that the intercooler might add is gone. The system is really easy to install, (except for the bit of fight the balancer bolt will give you) and with a price of about 5K its not bad to add an honest 80-100 RWHP.
Probably about the same power as you could get with a Full Heads, Cam, Intake, but with the SC you still maintain your 3yr/36K warranty and have CARB approval if you are in a state that requires it.
I have to pull the blower off the car again to install the LT4 injectors, when I do I'll do some pulls without intercoolers and water injection to see how much power it will make with that mod.
Completely agree with the water system risks, but I have what I feel is a fairly robust failsafe solution for those that would like to have it. It's being installed on my C7 Z06 right now along with the new LT4 TVS2300 Heartbeat. I'll provide more information about it and operating characteristics as soon as we have the car finished.
Old 12-31-2016, 04:50 AM   #65
laynlo15
Thanks Mike, we really appreciate your input. When Mike gets his done he'll pass on the Cals to me and I'll put them to the test here in Missouri on the street and the track. We may do the dyno pulls this Sunday depending on how my buddy feels after his New Years Eve party he's having tonight. I'll let everyone know of the results. After driving the Camaro a couple hundred miles since my install I'm guessing he's right, probably 100 hp gain at the 5.5 boost level.
