#57 |
Drives: 2018 Camaro SS 1LE, 2019 Camaro 2.0 Join Date: Sep 2011
We're going to be running our car when it cools off too, we just picked up a 2017 turbo as a shop car. This was a mild tune, we're going to really push ours stock and see what we can do with no parts. Then install our intake tube, downpipe, and some other goodies we've got up our sleeves.
#58 |
![]() Drives: Camaro 2.0 2017 8 speeds Join Date: Jun 2017
those anywone a some specs of this Camaro ,Thanks
#59 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
First weekend out drag racing had a blast with darknightmaro the conditions were deplorable for good numbers but i'm happy with it. Now i'm hooked though lol. Need to get the tune figured out. Even darknightmaro's car ran faster then the V6 guys outside of the built FI guys and we outdid a lot of stock V8's
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
#60 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Yeah, lots of people said it was heat soak city. Good job!
Kindness and compassion #OthersFirst |
#61 | |
Blessed ❤️
#62 | |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Now just need to retune for the new meth injection and get back out there again. The next race I could feasibly make is Aug 26. Should be able to get it dialed in by then... Sadly after that race there are only 2 more races in our season, Sept 30, and Oct 21 Then the season is over... After the Aug 26 race, should do the FMIC and Big turbo if time allows... Unfortunately, there is a very good chance that after this season ends, the local track will not be reopening next year, unless someone with deep pockets shows up and does something about it. If that's the case, I'll probably only get to race once or twice a year if I'm lucky as the next closest track is 3-4 hours away. Might as well put the car back to stock if the track doesn't reopen. |
#63 |
#64 |
my new record
#65 |
Blessed ❤️
#66 |
#67 |
my mods
I do all myself
custom exhaust no cat no mufflers,custom air intake with 2014 pcv tubing,charge pipe with 67mm throttle body,front skinny on 15 with 1.5 spacers and 28-10-17 Hoosier slicks 17x8.5 Vette front wheels,water/methanol injection,PCM tunned with HP Tunner,not finished at this time... It s my only car , I can ship my TCM now to tune... |
#68 | |
there isn't a whole lot to gain in the trans tuning, as we dont have the ability to TUNE the toque management, its either ON or OFF for the upshifts. I have found it to shift slower with the TM turned off. |
#69 |
what I see is the throttle close 1 sec between all my shift :O ,when I tune the trans I erase that , and the torque management I will tune too ,with the time between shifts... like you sead a lot of gain for sure and better Densité/Altitude like September/October near to 0 DA or -...
#70 | |
Official 2016+ I4 LTG 1/4 Mile Fast List
Nothing in the transmission side will fix that, it's all in the engine side of the tune that controls the throttle closing on shifts. And the torque management on the transmission side can not be tuned yet. You can either turn it ON or OFF for the upshifts and down shifts. There is so many missing tables it's stupid. It's not like the older 6 speed automatics where everything has been implemented and everything is tunable. It's pretty limited still for the A8 which sucks Sent from my iPhone using Tapatalk Last edited by Jason@JacFab; 08-15-2017 at 07:04 PM. |
