#57 | |
![]() ![]() Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
#58 | ||
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
#59 |
![]() ![]() Drives: 2016 2SS Garnet Red Camaro Join Date: Aug 2015
Why is that data important to a regular non-engineer driver of a new Camaro?
Ordered: 8/8/15, 2SS Garnet Red
Built: 10/14/15 Current: Took Delivery, 12/24/15 Added Procharger supercharger. ![]() |
#60 |
Drives: '69 RS Pro Street Join Date: Feb 2016
#61 |
Drives: 2016 2SS Join Date: Mar 2014
If I can run a 0-60 in 3.9 in a manual 2SS it would be a joke if the ZL1 couldn't take the base vette.
#62 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
#63 | |
![]() Drives: New Join Date: Sep 2012
#64 | |
The Dogfather
~ Lao Tzu I truly love data and knowledge plus there are those on this forum as well does too. Why forums exists. Not just for "what color I should get". And by no means am I an engineer, just by heart, not tradecraft. |
#65 |
![]() ![]() ![]() ![]() Drives: '06 Pontiac GTO M6, '19 F150 2.7TT Join Date: Nov 2008
What GM really needs to do is figure out how to get rid of the almost 200 lbs it has gained since going to c7. That alone will drop quarter mile .2 secs.
#66 |
The 16 Camaro A8 is almost as fast as the base vet. Zl1 will probably run with the C7Z since it will have the A10.
#67 | |
#68 |
Not sure I understand this thread regarding the ZL1 and base C7. The ZL1 will easily beat the base C7. The 2016 Camaro SS is capable of that or at least run neck and neck. The Corvette is Chevrolet's "Halo" car. It will be improved and re-engineered in a very short time to again be the halo car at Chevrolet. With the ZL1 and Z06 both at 640 HP and 650 HP respectfully it should be amazing.
#69 |
![]() Drives: Fuel efficient compact sedan :) Join Date: Jun 2015
I'm curious to know how much downforce it will have, and if it will slow it down at higher speeds....
#70 | |
![]() ![]() Drives: 2016 Corvette Z06 Blade Silver Join Date: Jun 2009
Also the vette has a long time left as a C7. They are expecting to "show" the C8 in 2018. That is 2 years away and I would expect 1 more year before you can buy one. Also the whole 10 speed verse 8 speed. In a drag race extra gears are not a benefit with a huge HP and massive flat torque curve engine. So a 10 speed could be a negative. (but rock on a road course) Even shifting fast there is a delay between gears. When you are measuring performance in tenths of a second it can add up if you have to shift more. (Many drag cars are 2 speed and top fuel is direct drive with no trans at all.) That will be very interesting to see how it does. My guess is the Corvette will not see the A10 trans for awhile. The Corvette has a "transaxle" (bolts to rear end) were the A10 is currently a transmission (bolts to engine). My guess is it will come but might even be delayed to the C8 release.
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD> Roto-Fab CAI 2010 2SS/RS BLACK on BLACK <SOLD> 3" MBRP 304 Stainless Exhaust Roto-Fab CAI |
