Old 10-07-2015, 10:00 AM   #57
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Originally Posted by hotlapZL1 View Post
Torque is force
HP is the rate the force can be applied.
That's pretty close. Work is the application of a force to a mass to move it (mechanical work). HP is the rate of work and can be expressed as foot-pound-seconds. This is directly related to a drag racing because you move a certain distance (1320 ft), in a car of a given weight (say 3950 lbs) in some number of seconds (say 12.9). If you have more horsepower you can go further for the same weight and time, push more weight for the same distance and time, or get there faster for the same distance and weight.
This is average horsepower and not peak horsepower, and it doesn't matter what type of force is applied (it could be a rocket engine that produces zero torque). You can have a 1000 lb weight dangling over a cliff held by a rope run through a pulley with a radius and 1 ft and produce 1000 ft-lbs of force. If the end of that rope is tied to something immovable, then no work is done and no power is produced. Fat lot of good all that torque is doing you, right?!? Tie the end of that rope to a 100 lb sled and then it will move the sled (work) and pull it all the way to the pulley in some amount of time (power). Make the weight 2000 lbs and you increase the torque AND the power, because:
HP = (RPM * TQ)/5252
And for all those that say the HP is just calculated and TQ is what matters, just a little algebra yields:
TQ = (HP * 5252)/ RPM
Torque can be calculated, too. Both TQ and HP can be measured and the other can be calculated by simply knowing the RPM.
Low end torque only gets the car moving because allows for more power. Assume you launch your car at 3700 RPMs
300 TQ at 3700 RPM = 211 HP
900 TQ at 3700 RPM = 634 HP <-- gets off the line quicker!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-07-2015, 10:08 AM   #58
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Originally Posted by DenverTaco07 View Post
Or it could be a really efficient drivetrain 10% loss would give 405 at the wheels, 450 at the crank. I don't know if 10% is realistic or not, if not you are right, or it's a ringer.
wait wait, they are saying 455 HP on the SS...that would be a 89.2% efficiency rating.
Using stock 426hp #'s for my 5th Gen....my drive train loss was 9% before my build (baselined @ 387WHP in GA).
Not calling you wrong and obviously different motors/gearing/cars etc....was just stating.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 10-07-2015, 10:16 AM   #59
SpeedIsLife
Drives: Current Camaro-less
Originally Posted by joemosfet View Post
For comparison, the Scat Pack Challenger dynos at around 430rwhp. Even with its added weight, I'll have to line up my new Camaro with my new Charger Scat Pack and see which one wins, and swap drivers too, to see if its consistent.
Note that my Camaro will be an M6 while the Charger Scat Pack was ordered with an A8. Around corners, there's no question the Camaro will win, but... is that extra 25 horsepower enough to make up for the added weight?
(also, which one will be delivered first? TPW of 10/19 for the Camaro and a production week of 11/9, but it seems that the Charger has quicker delivery times?)
I wouldn't say it's fair to compare the two cars..
However for a 4 door the Charger is quite quick and very aerodynamically slippery.
That being said as long as there are no parts restrictions..the average order to delivery time on Chargers is about 6 weeks.
Old 10-07-2015, 11:09 AM   #60
hotlap
hotlap's Avatar
I was trying to express as simply as possible for non engineers that both HP and torque are important. It’s not just HP, HP, HP. A very high rpm, high HP engine that is relying on momentum has disadvantages in the real world. Knock it off its speed and it needs time or gearing to recover. Tesla electric (max torque and zero rpm)
Regarding HP being a physical thing. Torque can be felt. RPM can be observed. HP is a function of those physical quantities
Ronald Reagan -
Old 10-07-2015, 11:13 AM   #61
GretchenGotGrowl
Oh, I know. I was basically expanding on what you said.
I will add this as well. Most drag racers consider the powerband to be between the the peak torque and peak hp. They use things like torque converters and gearing to keep the engine RPM between those two points all the way down the track. It the general idea is to have the highest average hp all the way down the track. Since you have a limited number of gears, that has typically been the best way to achieve the goal.
Old 10-07-2015, 11:14 AM   #62
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Originally Posted by Gen_Nick3.8 View Post
Most people who buy manual buy it for the fun & connection with the car. I had a BMW DCT & Gen 3.8 8sp. They're extremely fast shifting but after a while it gets very very boring all you do is floor it and go fast. Manuals never gets old, now that we have Rev-Match I feel like manuals are more attractive than ever
I'm still not tired of my 8speed auto and didn't get tired of my DCT before I traded it in but that's probably because I spend a lot of time in traffic now and don't consider my BMWs muscle cars . If I could afford it, I'd buy one of each but I can't justify to myself buying a car that is slower with a manual and for what I'm going to be using it for (Daily driver in traffic). If the manual was faster, I would still consider it the favorite. I will likely rarely track the car. I'll still drive both, but the pendulum has definitely swung in the autos direction for me.
Eric SS is offline   Reply With Quote
Old 10-07-2015, 11:37 AM   #63
newb
newb's Avatar
Drives: 2013 1LE
I am amazed, yet not surprised, that my underrated joke has completely derailed this thread and made it a scientific discussion of torque and Hp.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 10-07-2015, 12:09 PM   #64
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
Technically, it's up to you if the manual is slower or faster than the automatic.
xgnxs is offline   Reply With Quote
Old 10-07-2015, 12:51 PM   #65
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
Originally Posted by rayhawk View Post
Horsepower is not a marketing or legacy term, it just happens to be a measure of power based in U.S. units. Watts are no more proper than horsepower, they just happen to be based on the metric system.
Just because it's widely used in the U.S. as a unit of power doesn't mean it isn't a legacy term. I mean, you're comparing your car to a horse. Horses existed before cars. It's a legacy term used to help people sell cars over 100 years ago. I'm not debating that it's a widely use term today, obviously, but you can see where its roots come from. "Legacy" can mean out of date, or still current but in need of replacement. I think the term "HP" needs to go away, but maybe I'm alone on that.
Just think how weird it would say to state "My fancy new LED bulb puts out the brightness of 20 candles." We don't use weird associations like that. We use a standard measurement that stands on its own -- lumens. I think persisting to using the term "horsepower" is honestly equally ridiculous even if common in practice.
But what else do you measure in horsepower other than engine power? It's so limited in its application. I think the most proper term should be the one that fits best, universally. If watts was truly no better than horsepower, again going to the lightbulb analogy, people would be rating lightbulbs in horsepower and not watts. Which would be weird for sure.
RenegadeXR is offline   Reply With Quote
Old 10-07-2015, 01:07 PM   #66
GretchenGotGrowl
That's really not a good analogy. Candlepower is still used for brightness in a particular direction. Lumens is used for total output in all directions.
The reason we don't use horsepower for lights is horsepower is a specific type of power (like thrust is a specific type of force). There is no mechanical movement in a light bulb so no horsepower. There is an equation that will convert between watts and ELECTRICAL horsepower, but no one uses that because watts is a better measure. There is a difference between electrical power and mechanical power.
Old 10-07-2015, 01:10 PM   #67
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Yeah, just saying, footcandles is still the unit of measurement used by the FDA to determine sufficient lighting in milk plants.
2023 GMC Canyon Elevation
Old 10-07-2015, 01:14 PM   #68
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I understood what you were trying to say. SI is a legacy measurement system. Metric is the accepted scientific system but marketing in the auto industry has kept HP and ft lbs of torque around as what everyone uses.
With cars now featuring electric motors, watts is starting to gain some traction, but will likely be a long time before SI is replaced.
Old 10-07-2015, 01:19 PM   #69
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
Well, any use of power can be measured in horsepower or watts.
If you are referring to the units that people most often use when measuring power, sure, it's generally devices that output rotational or linear motion. My garbage disposal advertises its power in horsepower units, for instance.
But just because it's not used outside of those types of devices doesn't mean it is an invalid unit of measurement.
Similarly, we measure our furnace in BTUs per hour, which is also a measurement of power and can be directly converted into watts. There is also "metric horsepower" as well.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 10-07-2015, 01:29 PM   #70
Eric SS
#becauseracecar
Eric SS's Avatar
Maybe a dumb question but how is it up to me? No way will the manual be faster than the auto with the same person driving IMHO.
