#645 | |
![]() Drives: 2016 2SS Join Date: Jan 2016
https://i.ytimg.com/vi/S0hRzEihsR4/hqdefault.jpg
#646 | |
My grandson is getting big enough to do that, think I will avoid letting him see how I open the gas fill cover whenever he is with me at a gas station
#647 | |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
#648 |
Hot Camaro
Not sure whether this works for any/all prior years, but if you turn the car off with the high beams on, they will automatically reset to low beams when you start the car and they come on again.
My car is a '20 2SS in case the trim level or year matters here. I also wanted to add a couple of comments about some other items in this thread: - Cruise Control in a Manual: If you shift gears with cruise control set, cruise will not cancel out unless don't shift into a different gear within about 2 seconds or so. If you take too long to change gears, it WILL cancel cruise control. - Hill Start Assist in a Manual: The clutch has to be depressed - the car does NOT have to be in any gear - in order for it to engage as long as the grade is "steep enough". If you fail to attempt to move within about 2-3 seconds, it disengages and the car will roll. If you take your foot off of the brake with the clutch OUT, it will not engage. |
#649 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
It's the only way I drive it in manual mode...don't like using the paddle shifters, especially when turning!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
#650 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
I didn't know that the issues with the 8 speed transmission were not random manufacturing issues related to the 8l90 only ....and are actually something every single 8l45 and 8l90 produced will experience due to the fluid they used up until the 2nd quarter of 2019.
we all will have failing transmissions. It's only a matter of time depending on the weather we happen to be driving around in most often. ...and somehow no recalls have been made. took mine 4 years but i only have 35k miles on the car and live in a place that doesn't rain all that often or get very cold ever. |
#651 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Easy answer for me. For my 2016 (bought new to me this spring) I didn't know I'd fall in love with this car as much as I did.
#652 |
Howdy! Pete here...
I don't have Nav (or Sirius XM) but I do have a working Weather Channel app on MyLink. Downloaded to MyLink via the app store. Works great!
PnCRedJwl2SS
#653 |
![]() Drives: 2018 Camaro RS 3.6 A8 Join Date: Jun 2018
If you long-press the home button on the infotainment panel , it displays the Apple CarPlay interface on the touchscreen, or presumably Android Auto if that's enabled.
#654 | |
Howdy! Pete here...
Or... you can just say "Hey Google" if your Android phone is correctly set up to listen for it while locked and driving, (check your Google Assistant settings) Very convenient!
PnCRedJwl2SS
#655 |
Howdy! Pete here...
Yes it is...
Also, did you know that, if you have the heat seat or ventilated seats set to run on auto, they will run automatically upon remote start on the A8 (under the appropriate outside temp conditions), but will turn off as soon as as you push the engine start button? If you then want seat heat or ventilation to continue, you must turn it back on.
PnCRedJwl2SS
#656 |
Howdy! Pete here...
I turned this tracking off immediately upon finding out about it! Don't recall exactly how. I think I had to log in to my Onstar account.
PnCRedJwl2SS
#657 |
Hot Camaro
#658 |
Drives: 1ss Join Date: Jul 2016
Learned new today!
Braking hard in sport mode activated performance shift. I never noticed that in my RS, but maybe it's a SS thing. Unlocking performance shift mode is really fun...like getting a bonus level on a video game or something! It doesn't seem to do it all the time on hard acceleration.
