Old 10-21-2019, 08:28 PM   #631
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Originally Posted by M0DRN71 View Post
Spacers up front only, or at all 4 corners?
Just up front. Rears bolt right up perfectly.
Provoste is offline   Reply With Quote
Old 10-21-2019, 08:33 PM   #632
Provoste
Provoste's Avatar
Originally Posted by Provoste View Post
Track =Mid Ohio Club Config
Elapsed Time=1:36.24
Camaro Model = '17 SS 1LE
Date=10/13/19
Tires=OEM ZL1 1LE Goodyear 3R's (305/325)
Mods= Hawk DTC 60 pads, front strut camber mod, ZL1 1LE wheels/tires.
So I decided to bolt up the ZL1 1LE OEM ties on OEM sized/offset BC forged wheels. Wow, I was blown away. How early you can go to throttle with the 325 rear is mind boggling. Pretty unreal for a OEM 100tw factory tire. This is a pretty damn solid lap, I had a mid/high 1:35 indicated on my Aim Solo, but I got a touch loose in the carousel at the end of the lap. Enjoy!
Interesting aside- same day, best I saw on my 305/30 19 square Hankook RS4’s was a 1:39.6. That was pushing HARD too! 3.4 seconds on a 1:40 lap is pretty crazy. Pace differential I’d expect on slicks, not 100tw tires.
Old 10-22-2019, 07:50 AM   #633
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I keep seeing a lot of this, seems the G3Rs are as good as slicks.
Old 10-22-2019, 10:14 AM   #634
Provoste
Provoste's Avatar
I have a lot of time on slicks, and was running with a good friend on PZero DH's this same weekend. Agreed, the 3R's are closer in times to a DOT slick (Hoosier R7) than they are a street tire. They are at least a second slower at Mid Ohio vs. a non-dot slick (Pirelli DH). My friends on DH's would close me in slow mechanical grip corners when I was on the 3R's.
Old 10-29-2019, 12:33 AM   #635
Stormtrooper1le
Drives: 2018 ZLE
Track- VIR
Time- 1:57.93
Date- 10/26/19
Car- Camaro ZL1 1LE
Mods- AP brakes, hoosier a7s, full exhaust/intake+tune, some extra aero.
Fast lap is the second lap
https://youtu.be/Lz2ynlLVi8o
Stormtrooper1le is offline   Reply With Quote
Old 10-30-2019, 06:34 PM   #636
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Date=10/13/19
Do you like the DTC 60 better than the DTC 70?
Old 10-30-2019, 06:51 PM   #637
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
I’m only speaking for myself here, but I went from 70’s to 60’s and hated them. The bite felt inconsistent (and I had new fluid, so it wasn’t that) compared to the 70’s. The 70’s never gave me a reason to doubt that I would stop, and the 60’s had me nervous going into the end of the back straight at Mid-Ohio.
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 10-31-2019, 08:45 AM   #638
TrackClub
TrackClub's Avatar
Date=10/13/19
Holy $hit Eric That's faster than all stock ZL1 1LEs that posted their laps - except for one (and not counting your own on Pirellis). Congrats!
PS did the rears just bolt on, or did ya have to move the harness out of the way?
Old 10-31-2019, 12:05 PM   #639
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Not speaking for him, but on my 17 SS 1LE, in the rear, both 345 R7's and 325 G3R's (almost the same OD & Section Width) did not rub on the wheelhouse liner nor wiring harness using OEM 19x12 ZL1 1LE wheels. Stock ride height, stock FE4 suspension.
Up front required the normal strut grinding with -2.7 front camber with the ZL1 1LE fronts (305 G3R's and 315 R7's).
RUQWIKR is offline   Reply With Quote
Old 10-31-2019, 12:29 PM   #640
Provoste
Provoste's Avatar
Thanks, yeah the car was just insanely hooked up. If you watch my throttle trace at every corner, it is mind-boggling how early and hard you can go to gas with the wide rear wheel/tire.
Rears bolt right up, no fender-liner contact. No harness movement.
Old 10-31-2019, 01:10 PM   #641
TrackClub
TrackClub's Avatar
Thanks for the info you guys...jeez i may have to open up my wallet next year lol! Do these big boys fit inside the car?
Yep i have watched your vid very carefully Eric and you were on power very soon indeed! Superb pace!
Old 10-31-2019, 01:55 PM   #642
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
You can get five 305-325's in the car if you want. One in the trunk, three across the rear seat area, one in the front passenger seat - if you really want.
For the trunk, I have the rear plastic cover off of the latch striker. If putting a 12" wide rim'd tire in, I take off the latch striker (two bolts) - have it paint marked to the body for quick alignment.
Old 10-31-2019, 02:51 PM   #643
TrackClub
TrackClub's Avatar
Thanks again! Cheers!
Old 11-11-2019, 02:57 PM   #644
Wally746
Wally746's Avatar
Drives: 2018 Camaro SS 1LE PDR
Track =Daytona Road Course (Fast Lap 2.19mins - starts in video at 2.56 mins)
Camaro Model = '18 SS 1LE
Date=11/9/19
Tires=Hankook RS4's (305s)
Mods= Hawk DTC 70 pads, front strut camber mod, Forgestar CF10 19x10 wheels, Hankook RS4 tires.
Wally746 is offline   Reply With Quote
