Old 11-21-2025, 03:17 PM   #43
JSH
JSH's Avatar
Drives: '20 ZLE
It made 1045/1055 today. Race gas only.
It did not make 1040 2 weeks ago because I misread the Dyno sheet. The 1040 represented a blip when the car shifted to 7th. I don't have the exact number, but it looks like from the lines on the graph it probably made around 980/980.
All the numbers look great. 22.5°. lambda going down from 85 early to 81 at the shift point. MAT 85-90. No negative advance or retard or any other similar type of events. The car ran real good
I feel sure that an excellent race gas tuner such as Joe M. Could get considerably more power out of it but for today it is what it is
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 11-21-2025, 03:56 PM   #44
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Congrats! Hopefully you're back on track.
Old 11-21-2025, 04:02 PM   #45
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Solid numbers! Hopefully she is good to go now.
Old 11-22-2025, 06:35 AM   #46
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Originally Posted by swisstyphoon View Post
How did you first notice the leak on yours? Were there any other signs or symptoms that tipped you off before you confirmed it? And how bad was the leak once you found it? I’m asking because my recent oil analyses showed elevated numbers, but there haven’t been any obvious issues.
I’m just trying to figure out whether my pump might be starting to seep a little, or if the elevated numbers are simply from running ethanol and the larger injection window.
Fuel trims would start going positive at idle and the car would go way rich. Would also want to keep running after I shut it off. Could smell fuel out of the TB. Ended up being that safety relief valve that failed.
CamOnlyJabroni is offline   Reply With Quote
Old 11-22-2025, 10:13 AM   #47
KingLT1
KingLT1's Avatar
I thought they were going extremely negative?
Old 11-24-2025, 04:16 PM   #48
CamOnlyJabroni
You’re right. Negative fuel trims.
Old 11-25-2025, 04:20 PM   #49
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Thanks for your help and the detailed answers guys. I’m not seeing any fuel smell, run-on, or strong negative trims on my end, so nothing obvious so far. Just trying to figure out if the elevated numbers in my oil analysis are an early sign of a small seep, or simply from running ethanol and the larger injection window.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
