Old 03-30-2024, 12:53 PM   #43
Kevin76
https://www.instagram.com
Kevin76's Avatar
Drives: 2018 Camaro SS 1LE
Abandoned Dragstrip Slideshow
I took a drive to see what was once a very busy track. Good memories but sad to see its fate.
https://www.instagram.com/reel/C5EZm...hocHdhdzZ3OQ==
Kevin76 is offline   Reply With Quote
Old 04-26-2024, 02:07 PM   #44
Kevin76
Kevin76's Avatar
Air/ oil cooler
Oil temps got pretty warm at the last track event. Ambient temps in mid 90s had oil temps above to 260. It’s see what this cooler set up can do.
Old 05-17-2024, 07:35 PM   #45
Kevin76
Kevin76's Avatar
Cooler results
I saw an approximate 15° improvement in oil temps on a 97° day. It definitely stands out behind the grille.
Old 05-18-2024, 06:44 PM   #46
Kevin76
Kevin76's Avatar
Just another track day
https://www.instagram.com/reel/C7ICC...htbGtydjYzaQ==
Old 07-05-2024, 04:34 PM   #47
Kevin76
Kevin76's Avatar
Get a catch can!
2 track days and some DD
Old 09-06-2024, 11:18 PM   #48
Kevin76
Kevin76's Avatar
Did a thing
Old 09-07-2024, 01:13 PM   #49
Kevin76
Kevin76's Avatar
19x11/12
19x11/12 305/325
Old 10-01-2024, 04:05 AM   #50
Kevin76
Kevin76's Avatar
Headers
Adding some BBK headers
Old 10-02-2024, 06:04 PM   #51
Kevin76
Kevin76's Avatar
BBK headers to Speed engineering X pipe
BBK headers and high flow cats to Speed Engineering. Still needs the connections welded
Old 10-06-2024, 09:35 PM   #52
Kevin76
Kevin76's Avatar
Sound clip
https://www.instagram.com/reel/DAwkX...Vkc2ZvcjdyMGNu
Old 11-10-2024, 09:12 AM   #53
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Nice straightforward build, great job
Cam in your future?
Old 11-30-2024, 07:29 PM   #54
tortilla-flats
tortilla-flats's Avatar
Drives: 2023 Camaro 2SS
Enjoying this build! Thanks for sharing.
tortilla-flats is offline   Reply With Quote
Old 05-07-2025, 06:42 PM   #55
Kevin76
Kevin76's Avatar
Aluminum bushings
Replaced the BMR motor mount bushings after the started to deform.
Old 05-07-2025, 06:55 PM   #56
Kevin76
Kevin76's Avatar
ACS Composite splitter
Smoked the front splitter hitting some debris in the roadway. I replaced it with the ACS Composite splitter. This is the ZL1 in the 1LE color. All the bolt holes line up but you do have to drill some holes for the rivits.
