#43 | |
Electrical Engineer
The short summary is that it's quiet enough now that you only hear the engine/exhaust when revs are high, and tire/road noise is mostly gone. A small bit of music is all you need to overcome everything else - which achieves the desired goal. I can have music on at a comfortable volume, near conversation levels, and the music is all you hear. When going over bumps, you'll get a small bit of suspension noise, but nothing annoying. Treating the wheel wells was a huge improvement as a step 2. Nothing comes from the rear, it's really quiet back there and rear passengers say that the only noise they hear is from the front. The firewall is not treated. The floors could be treated a bit better with added barrier on top of the CLD. That may be a spring project. As far as weight, about two Americans. Center of gravity is lower and more rearward. This is a daily driver, not a racecar, so some added weight to make it more enjoyable is totally worth it.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#44 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Just amazed. My skill level for something like that is a -2 if the scale is 1-10. I would of never thought to do the wheel wells, that was just awesome. Beautiful work!
#45 | |
Electrical Engineer
The wheel wells are a huge source of noise. I fully treated the rear quarters so those wheel wells are treated from inside but I couldn't get to the front quarters any other way.
#46 |
![]() Drives: Chevy Camaro ZL1 Join Date: Dec 2023
Great read. Any current updates ? I just found this build and love it.
I'm doing the same in my '19ZL1. I'm actually changing it up again. About to do all the Bose replacements next. Either audiofrog or hertz. I'm running the Axxess-AXDSPX-ETH1 to 2 mini max 1004s and a jp43 . But changing out the 1004s for the 34ab again. 2 of em. A single X12v3 for sub. Soon as LLj customs starts to make loop ack harnesses again I'm grabbing one of them and doing a Helix DSP. I really dislike this axcesaa one. Anyways would love to see more of this build. |
#47 |
Fantastic write up! I am also in the process of a build using a fully active 3 way Audiofrog GB10,25,60 system in my 19 ZL1 and this has been an amazing read full of tips and info to better my system setup. Unfortunately I get to content with the Bose OEM amp, but hopefully my Axxess interface paired with a Helix DSP Pro MK3 will be able to get a clean and workable signal for me. I love the attention to detail you put into both your build and the writeup of the process, thank you for all of that as it really helped in the final planning stages before starting right after the new year.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
#48 | ||
Electrical Engineer
Thanks! The update is that I am still enjoying the quiet ride and the vast improvement that the new speakers provide. Life is busy and thus I am waiting for the next steps, which include a measurement of the factory EQ and then integration of the JL MVi amplifiers. Then I'll have to modify the dash covers in order to fit the ML70 and ML28 in, which will happen when it warms up in spring. Quote:
I specifically ordered my car without Bose to simplify the process, but also chose the 1SS over the LT1 to get the 8" screen (along with the other benefits).
#49 |
Electrical Engineer
After the noise treatments in the doors, floor, and rear of the Camaro, I turned my attention to the firewall. These vehicles have a tube that runs from the engine intake pathway to the firewall, with a diaphragm to isolate airspace but allow sound to pass through. The solution is to 3D print two pieces that let you plug each of the holes – one at the firewall and one at the intake pathway, just before the throttle body. I printed these out of ABS.
The fire wall connection looks like this: ![]() ![]() [img]https://hosting.photobucket.com/images/e128/phat_funky_beats/20240124_211949.jpg[img] ![]() The hose connection at the intake pathway looks like this: ![]() And the rubber hose clamps are easily opened and removed as they just use push-clips. ![]() The diaphragm is held with T50 Torx bolts: ![]() ![]() With the hose removed, you have this: ![]() The result at the firewall is this piece with butyl gasketing: ![]() The result at the intake pathway is this plug that fits perfectly: ![]() ![]() The result is very noticeable. All of the intake noise is gone. The chugging noise from V4 mode is gone. The cabin is much more comfortable.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 Last edited by keep_hope_alive; 07-03-2025 at 12:10 PM. |
#50 | |
![]() Drives: 22 Camaro 2SS A10 Join Date: Jul 2010
I'm curious as to why you are using the marine versions of those JL amps. Also, I read the description for the MVi hub, and just like the rest of your install, is pretty over the top (in a good way). Does Cat5 Ethernet cable connectivity improve sound quality over using RCA cables? Is the Cat5 Ethernet cable connectivity and app control worth $450? Or is it like the audiophile equivalent of buying a RTX 4090 for a PC?
2022 Camaro 2SS A10
2007 Trailblazer SS |
#51 |
![]() Drives: Subaru WRX Join Date: Apr 2019
Eagerly awaiting updates on this, I’m starting some of my build soon, but really curious to see what you do for an amp rack as I’m already stealing so many ideas here.
Definitely won’t be going as in depth with sound deadening but planning on doors, trunk and trunk lid to start. Using 2 helix amps, one with the built in dsp and stereo integrity mids with audio frog gb15 tweeters. Can’t justify going to nicer subs yet as my p3 Rockfords are still kicking, but once those go, want to go a more sql route on the subs as well. |
#52 | |
Electrical Engineer
A few delays; getting a new engine in my Camaro was a big delay, and I have a few other projects that I've started that have higher priority. One is a 2010 Accord that I've gutted to clean as it's going to my youngest daughter and was a smokers car. It needs a lot of mechanical, cosmetic, and interior work to get right (was cheap). ![]()
#53 | |
Electrical Engineer
Why Marine MVi? Good question. Simple answer: I was on the Beta Test team and I have them. I'm using 14awg speaker wire from the factory head unit to the 600/6i for front audio inputs, high level, balanced. Then RCA from 600/6i output to 1000/1 input. The Hub is there for programming ease, so they communicate since all tuning and adjustments are thru a laptop. in my case, it's not really needed and I could just have two USB ports in the rear facia to access the amps. Historically, I routed USB cables to the cabin for ease of programming while listening.
#54 |
Electrical Engineer
November 2024 Update:
I've just been driving it since I got the new engine. I'm at 37k mi. now need to find a window of time to tear into it more. I have MLV to install on the floor for further noise reduction. I need to install the amplifiers and decide on a subwoofer location and size. While tempted to just trunk-baffle and replace the rear seat with a sub wall, I cannot fit golf clubs in the car without folding the seat down, something I want to continue to do. I daily this, so I need the extra trunk depth on demand. That means the best bet is the driver's trunk corner... where I want to put the amps. But if I do the rear corner for a sub, all of my noise isolation in the rear deck is pointless as i'll have to open the space back up. I like running front 3-way components active, so that means doing a lot of modifications to the dash corners to integrate mids and tweeters. Likely 3D printing components. Removing the windshield to would make this easier and allow me to remove the headliner. Not gonna happen this year. May likely just run a 2-way front for now, I've already made brackets for tweeters in place of the stock full range in the dash. If I stay front 2-way, I may install my high-output Hertz 6x9 in place of the rear/side speakers, in custom enclosures. This would allow for high-output music with windows down, and they would be off for most listening with windows up (to enjoy the sound stage). Possible as rear-fill to enhance soundstage depth with a lot of processing. TL/DR: I have a lot more planned.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 Last edited by keep_hope_alive; 04-10-2025 at 11:11 AM. |
#55 |
![]() Drives: 2022 Camaro SS 1LE Join Date: Sep 2011
I’m getting ready to upgrade the sound system in my car later this year and have a question or two for you. I’m looking at applying CLD under the black panel on the underside of the trunk lid. In looking this piece over I noticed that the edge of the panel will mostly likely vibrate against the metal of the lid itself with any sub woofer volume at all. Did you do anything to trunk lid? What can be done there to stop the potential for vibration and not be visible outside the black panel?
Mark
Sugar Land TX 2022 VOM Camaro SS 1LE |
#56 | |
Electrical Engineer
| Tags |
| acoustic, audio, speakers, stereo, subwoofer |
