Old 07-14-2023, 01:42 PM   #43
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
If gender is a matter of choice, what do you identify as ? Male 6m, female automatic.
Gen6cyl is offline   Reply With Quote
Old 07-14-2023, 01:53 PM   #44
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
What? You could say the same thing as it relates to 6 cylinder (F) and 8 cylinder (M). Now, I don’t subscribe to that line of thinking, at all.You like what you like for your own reasons…
Old 07-14-2023, 02:00 PM   #45
Keko
Keko's Avatar
Drives: 2023 ZLE M6
2023 ZLE M6
Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid
2024 Polestar 2 AWD
Keko is offline   Reply With Quote
Old 07-14-2023, 02:08 PM   #46
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
This 100%. I tend to not judge what people drive(6cyl, 8cyl, M6 or A10), but since he brought it up, I'll agree with this statement!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 07-14-2023, 02:10 PM   #47
Gen6cyl
Exclamation
I disagree, I would still be male.Just smaller.
Old 07-14-2023, 02:18 PM   #48
Gen6cyl
I got a caution sign. Better say I just joking. It's Friday!
Old 07-14-2023, 02:22 PM   #49
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
Originally Posted by Keko View Post
M6 all day. Driver experience is at the top of my priority list, and the M6 in these cars is truly excellent. Best feeling trans I've ever owned, even without the rev matching as an added bonus. Why not step up to a ZL1 as well
Agreed! And in additional to bonus point for M6 having rev matching, it also has cool Hill Assist feature which is really key as 90%+ of today's driver don't even consider you might have a manual and like to edge up as close as they can to you even at up hill traffic lights :-(
[Even w/hill assist (which works great) I like to get to the light early, shift to neutral and let it roll back a few inches so they get the hint that they might want to give me a little extra room!]
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 07-14-2023, 02:28 PM   #50
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Manual transmissions in this day and age are for want to be 25 year olds when you’re 50 and that’s it that’s all that’s everything. I have drove three in the tree to six on the floor and would not give up my 10 speed A for anything at my fragile old age.
Old 07-14-2023, 02:45 PM   #51
Gen6cyl
You are right, I am 61 and have that problem. I'm grateful my 6m lets me indulge in it.
Old 07-14-2023, 03:38 PM   #52
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Moving forward, any automatic transmission car I have needs to have active cruise control to follow the car in front of it. As roads have gotten so much more crowded, regular cruise control doesn't cut it for me anymore and ACC is a godsend in traffic, not having to brake or gas. It's really what CC should have been all along IMO. So if I had an automatic sports car...it would need this. My sedan has it and has for the last 3 models I've owned.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 07-14-2023, 03:53 PM   #53
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
If my m6 magically turned into an A10, I would immediately get rid of the car. Even people who don’t know how to drive a manual give me props for getting the m6 as when they see a car like this, they also believe it should be an m6. I’ve driven DCT’s and ZF 8 speeds and while these transmissions are an improvement over the slush boxes of years past, they still lack the engagement of a manual.
m6-lt1 is offline   Reply With Quote
Old 07-14-2023, 05:08 PM   #54
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Originally Posted by Wyzz Kydd View Post
How difficult was it to put in the eLSD? After doing that and upgrading your brakes, wheels, tires, and adding the extra cooling systems how much did you save?
I don't have the 1LE, so 4 piston brakes,
Wheels and tires is all I needed.
Picked up ZL1 Replica wheels with proper offsets and match tires sizes from 1LE
The easy gist of it is: If the wheels + offset + tires fit a 1LE it will fit any standard camaro that is not a 1LE. Except maybe the V6 versions. But I know the LT1 is basically a V6 body with V8 engine so I assume LT's would fit this category as well. The only real difference is ZLE which I think has the widest tires on the back of the entire lineup.
I used this site for get the info needed: https://www.wheel-size.com/size/chev...-usdm-62i--455
Old 07-14-2023, 05:16 PM   #55
FlukeSS
FlukeSS's Avatar
Originally Posted by JTS View Post
I agree the A10 is an excellent Transmission, the lag in shifting gears is slow , like the Throttle all electronic . I'm so use to Cables, from the old days , Cables are so instintanious, that's why in Drag Racing most applications still use a Cable . I'm not sure on this , but with an A10 trans tune you maybe able to get quicker shifts.
This is true as well.
Trans tune can pick up as much as 3/10th's in a 1/4 mile on a bolt on ZL1 for example.
Old 07-14-2023, 05:17 PM   #56
FlukeSS
FlukeSS's Avatar
Originally Posted by JamesNoBrakes View Post
Pretty sure the 1LE doesn't have any additional cooling systems over the SS, it's the suspension/wheels/tires, eLSD that are the difference. FE4 is more than just the shocks, there's the sways, etc. The eLSD modes were super helpful last weekend at autoX on the first few laps to get it down without pushing too hard early on (before heat was there for enough grip). I do wish we could access linear throttle outside of track though.
I believe all SS+ models have 3 radiators, the LT1 does not, which makes them bad at hot lapping and track course use. They over heat quickly. That doesn't mean people don't eliminate radiators though to reduce weight.
My last time at the dragstrip I hot lapped my car 3 times in a row without shutting down the engine. Had no problems with heat.
