Old 04-27-2023, 04:53 PM   #43
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Numbers are in. 863/838. Picked up 20whp/20wtq going from 25.5 to 27 degrees of timing on E80. A little surprised but thrilled at the same time. Feels stout on the street. Will get some 60-130 data when my matching 17x11 bead lock setup shows up.
https://youtu.be/5dIzGAS7z6U
CamOnlyJabroni is offline   Reply With Quote
Old 04-27-2023, 05:23 PM   #44
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Great numbers @coj!
Old 04-27-2023, 05:36 PM   #45
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Badass, congrats! I’ll be doing a cam and low side fuel system upgrade next winter on my build which is fairly similar to your “before” state. You are blazing the trail LOL.
CW3SF is offline   Reply With Quote
Old 04-27-2023, 06:05 PM   #46
JSH
JSH's Avatar
Drives: '20 ZLE
sweet
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-27-2023, 07:35 PM   #47
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Badass! How much boost did it end up pushing?
Old 04-27-2023, 07:43 PM   #48
CamOnlyJabroni
Great numbers @coj!
I was pretty stoked that nothing broke and most happy with utilizing the dyno for what it’s really for, dialing the car in. When he added a little fuel and timing and picked up over 20/20 I was hype.
That X-Port will do even better!
sweet
Thanks.
It moves around from 14-15psi. Starts at just under 15, goes down at around 5,300 then builds back up to close to 15 at redline.
Old 04-27-2023, 08:15 PM   #49
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
I picked this up used for a really good deal. I have heard through the grapevine though that people are having failures with the xport because of the epoxy.
Thank you!
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 04-27-2023, 10:01 PM   #50
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Solid gains from previous mods and dyno. Hopefully the rods stay in it with that much timing. The shitty stock thrust bearing hasn't been upgraded on your SBE and you are smacking it with a lot of boost and timing.
Old 04-28-2023, 08:04 AM   #51
JSH
JSH's Avatar
Drives: '20 ZLE
LOL. For my 1031/1004 dyno, I did zero tuning. Drove on, tied it down, warmed it up, made a pull, paid, and drove away. It might have made a gazillion if we had tuned it joking
2020 ZL1LE A10.
Old 04-28-2023, 11:04 AM   #52
CamOnlyJabroni
LOL. For my 1031/104 dyno, I did zero tuning. Drove on, tied it down, warmed it up, made a pull, paid, and drove away. It might have made a gazillion if we had tuned it joking
Here is the gain I was referring to. Dotted line is after the timing change.
Old 04-28-2023, 02:52 PM   #53
JSH
JSH's Avatar
Drives: '20 ZLE
Oh, I am not doubting the merits of dyno tuning. I was simply saying my 1031 hp was the 3rd pull in a "drive in, drive out" session using Joe's then-current tune.
2020 ZL1LE A10.
Old 05-10-2023, 02:32 PM   #54
CamOnlyJabroni
Does anyone have some back to back testing on MAT after installing an expansion tank? I have a LMP bumper support mounted expansion tank ordered. Will be here tomorrow. Adds 3 gallons of capacity to the blower side. My MAT is reaching 170 by 100 and pulling 4 degrees of timing by 130. Should run a 4 I think on 20’s still with full timing in the same conditions.
Old 05-12-2023, 11:11 AM   #55
JSH
JSH's Avatar
Drives: '20 ZLE
I just looked at my last run with the Xport and ADM reservoir last May, and MAT was 170 at 140 mph in 6th gear
2020 ZL1LE A10.
Old 05-13-2023, 01:01 AM   #56
CamOnlyJabroni
What upper and lower were you running? Apparently I still had some air in the system. Bled it some more today and mats are 30-40 degrees lower across the board. Bumped up to a 3.5 upper for this run but put the 2.25 back on to test again tomorrow. MAT looks a lot better.
