Old 03-31-2026, 06:49 AM   #43
Originally Posted by lynyrd View Post
I have this mat in my car, it hasn't changed anything, I still have water in the trunk.
Did you install the plug (part 39123504 as per TSB 18-NA-375) Corky talked about?
Old 03-31-2026, 07:17 AM   #44
lynyrd
lynyrd's Avatar
Drives: Camaro 2.0 LT 2018
Send a message via Skype™ to lynyrd
No, I haven't installed them yet, I wanted to know if they are installed from underneath the car?
2018 Camaro 2.0 LT Turbo, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights
lynyrd is offline   Reply With Quote
Old 03-31-2026, 07:26 AM   #45
The TSB says you need to drill a 30mm hole from the trunk, deburr and apply protection to the newly exposed metal surface, then install the plug from underneath the car.
Old 03-31-2026, 07:27 AM   #46
lynyrd
lynyrd's Avatar
Thank you for the information.
Old 03-31-2026, 12:45 PM   #47
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Is this problem limited to sunroof cars? Ive never had a problem and i wash my car a lot.
Also the TSB is building a safety net and not correcting the water intrusion. Instead of modifications to control the water that has entered, it would be smarter to make modifications to keep the water out.
bishopts is online now   Reply With Quote
Old 03-31-2026, 07:05 PM   #48
Corky
Corky's Avatar
Drives: 2019 1SS M6
Agreed...Although I have a sunroof car I've never had any water in the trunk even after some somewhat aggressive automatic car washings on the road.. The plug install went super easy you can pop it in from the bottom without being up on ramps...Sure is cheap insurance if the problem arises but as stated I'd be looking for the source not treating the symptoms...
1st Gen ground effects kit GBA black | Mamo V3 ported TB | GM CAI | Velossa Ram Air | AWE touring axle back| Xpel PPF | illuminated door sills | Upgraded door panels with spectrum lighting |ZZP pillar pod with Banks Idash pro/AEM wideband
Corky is offline   Reply With Quote
