Old 08-16-2022, 08:44 PM   #43
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Click the link in post #1.
Old 08-16-2022, 08:46 PM   #44
laynlo15
Drives: 2022 Lt1 A10
Don't make me do that.
Old 08-16-2022, 09:00 PM   #45
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I could have sworn that their latest rotor assembly was Roots and similar to Magnuson Roost rotor pack. Guess I was wrong but geez that was the first time today. Haha, still have 3.5 more hours to prove myself wrong again.
The Maggie is 4 lobe & 4 lobe for the rotor pack. The Whipple 2.9 is a 5 lobe & 3 lobe combo, while the 3.0 is 5 lobe & 4 lobe if I remember correctly.
Old 08-16-2022, 09:08 PM   #46
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Whipple doesn't manufacturer roots blowers. They are all twin screw.
And their screws are different than KBs, right?
'20 ZL1 Black "Fury"
Old 08-16-2022, 10:08 PM   #47
laynlo15
The Maggie is a high helix 4 lobe true roots blower. The 2.9 rotors being different sizes spin at a different rpms and I think that's ne reason the create higher IATs from what I understand.
Old 08-17-2022, 08:29 AM   #48
KingLT1
KingLT1's Avatar
The The 2.9 rotors being different sizes spin at a different rpms and I think that's ne reason the create higher IATs from what I understand.
Anybody reporting high MAT's with the 2.9 either does not have the IC system properly bled or they are over spinning it which will happen with any PD blower. Whipple needs a larger fill tank is the biggest problem with their kits. Once they are properly bled they run fairly cool. I have logged and tuned several different setups with 1.7's, 2.3, 2.65's, and 2.9's. There is a lot of biased info out there. I am not a "whipple guy" or "maggie guy". I like all setups and the tuning plays a bigger roll then the power adder brand/type on this platform.
The 3.0 is a 3 x 4. They did this for more air flow.
Old 08-17-2022, 10:10 AM   #49
KingLT1
KingLT1's Avatar
Side note...Whipple sent a email stating they will have Upgrade pricing in the next 30-60 days for those who want to move up from a 2.9.
Old 08-17-2022, 10:54 AM   #50
laynlo15
Old 08-17-2022, 11:01 AM   #51
Joshinator99
Moderator
Old 08-17-2022, 12:13 PM   #52
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
I really wanted to stay with the Whipple when I had it. I tend to want to lean away from anything that most people think is the best or needed because "that is what has always been done", and at the time people wrote the Whipple off before the 2650 even proved itself IMO. I ultimately caved but made sure to collect every data point we could on the same car (mine), same engine, same cooling, same fuel, same dyno, same blower RPM, and in mostly the same DA when doing comparisons. Thankfully I already had 100+ passes on the Whipple with data logs from each to put my mind at ease on the switch and I'll have more than that if I decide to give the new Whipple's a try.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 08-17-2022, 05:55 PM   #53
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Interesting strategy. They going to refresh and sell used ones now? That might be a good deal for some folks.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 08-17-2022, 06:55 PM   #54
Joshinator99
Moderator
I don’t think so. Probably more of a “make sure 2.9 guys don’t buy a 2650” move on Whipple’s part. Plus, I suspect it’s an easy upgrade since I think it’s the same 10-rib pulley drive system.
Old 10-25-2022, 03:27 PM   #55
Nmolina9239
Nmolina9239's Avatar
Drives: 2018 2SS
Have any of these hit the streets yet that anyone knows of? Might be my winter upgrade from the 2.9....
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
Nmolina9239 is offline   Reply With Quote
Old 10-25-2022, 03:43 PM   #56
ShredderZL1
Drives: 2017 ZL1
Out of curiosity, how much power were you making and what was your best ET/trap with the Whipple?
ShredderZL1 is offline   Reply With Quote
