Old 07-29-2022, 08:03 AM   #43
NG329
Drives: Chevrolet Camaro ZL1 1LE
Originally Posted by UFDUB View Post
Great job on the times and improvement!
Just to hear your thoughts, what made you choose these specific changes? Such as, why front cradle brace but not the back, or both? Why the tunnel brace? Based on any recommendations? How did you choose BMR over SPL, or anyone else?
Again, great job!
Basically I just eyeballed those particular parts and thought that maybe they could be a tad more rigid based on how the OEM parts were designed. They basically look like flat pieces of steel with flared edges.... which can be rigid but the BMR units with the tube design are definitely up to task based on what I learned from my bicycle days as it pertains to tube stiffness and deflection.
Regarding brands, honestly, it came down to my lack of knowledge. I was only aware of BMR since I'm relatively new to the car world. I just kind of went with them because of the readily available information on the WWW. I'll look into SPL.
Yesterday my Strut Tower Brace arrived and I got it installed along with the Solar throttle body. This car is begging for a tune now.
NG329 is offline   Reply With Quote
Old 07-29-2022, 08:11 AM   #44
NG329
Again, great job!
Also, I just want to point out that I was going for a particular "Feel" with the car. I'm sure that pretty much any brand that specializes in chassis components can achieve that. The stock car could certainly run my times with a good driver but I needed to wrap my head around how the front and rear of the car play together.
Old 07-29-2022, 07:59 PM   #45
NG329
Got the strut tower brace bolted up along with the Solar 87mm (91EFF) throttle body.
Absolutely zero body roll now. Zero.
Old 07-29-2022, 08:06 PM   #46
NG329
I also rotated the tires from left to right and upon further inspection, the fronts were cording only after that first track day. *sigh
Old 07-30-2022, 12:12 PM   #47
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
Flip them before the start to cord
Zl1+911 is offline   Reply With Quote
Old 07-31-2022, 07:22 AM   #48
NG329
Wheels and slicks mounted
Old 07-31-2022, 09:22 AM   #49
NG329
Went out for the first session and electronics went crazy. I ended up flashing the car here at the track with the updated tire circumferences.
Nearly missed the first session. Car was going into limp mode etc.
Old 07-31-2022, 12:24 PM   #50
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
give us some info on tire height deltas etc...any tire sensor issues which our cars require all or none to function properly?
Old 07-31-2022, 12:41 PM   #51
NG329
I changed the tire circumference in HP Tuners. I think it was 2154mm for the rear but honestly it didn’t help.
Every session the car throws TPMS codes, Service Axle codes, and when I turn off ESC and TC altogether, it actually manages to turn itself back on somehow. It’s been a complete mess.
I feel like I need to calibrate the Tire Pressure Sensors in the race wheels for the codes to start to go away.
Old 07-31-2022, 12:42 PM   #52
NG329
As far as lap times go I’m running 1:14.2 in traffic. I need some clear track to hit PRs.
Old 07-31-2022, 04:22 PM   #53
NG329
Consistently faster.
Old 07-31-2022, 09:29 PM   #54
NG329
Okay guys so basically the day went well but the car was quirky as hell.
Pirelli DH Slicks 315/680/18 Front and 325/680/18 Rear.
I changed the Circumference in HP tuners to:
Rear: 325/680/18 = 2154mm
Front: 305/680/18 = 2165mm
Unfortunately that didn't help with any of the codes the car was throwing. I guess it only helped with the speedometer.
I received the following codes throughout the day:
- Tire Sensor Errors
- The Traction Control light stayed on. I disabled the system and then it would turn itself back on randomly. Very frustrating.
- Rear Axle
- Fuel Pump Sensor B Low voltage Code U18A2 Weird!!!!!
After the track day, I set the tire circumference back to stock, flashed the ECM and mounted the OEM tires. The car was fine on the 3hr drive home. Not a single error code.
So I'm going to have the Tire Pressure Sensors in the wheels programmed and hopefully that will get rid of the errors next time.
Fast lap time of the day was a 1:12.20 and I lost some momentum due to traffic. That would have been a 1:11.x lap.
The Pirellis held up great and they did not cord after approx. 160 hard miles. So for me, 2 track days for $700 in tires is quite the bargain since I corded the GY3R after only 1 day. I think that will be my GoTo going forward.
As far as how the tires felt on track, grip was amazing and it was consistent. The tires NEVER LET GO and my fastest laps came during the final session. Ambient temp was 90*F and it took approximately 1.5 laps to get heat into the tires. I ran 32psi hot off the track after every session but started the day with 26psi front and 28psi rear. The Pirelli does have a softer sidewall and you really do notice it when you load the front in the corners. It took me some getting used to because I like my car feeling as flat as possible but eventually it all came good and I had tons of confidence to push the car. I feel that the Hoosier A7/R7 would be a closer resemblance to the GY3R just based on sidewall design. I may try those in the future as an alternative.
So now I'm going to take a few weeks off to recoup some $$$$ but at the next event I'm going to try and see if programming the sensors in the Apex wheels resolve the error codes I received today.
....to be continued....
Old 07-31-2022, 10:20 PM   #55
NG329
PDR Final Session uploaded. A handful of 1:12s in heavy traffic. The in cabin video is uploading in 4K. That's going to be a fantastic video.
https://youtu.be/kOmQdv0fbBA
Old 08-01-2022, 05:14 AM   #56
Zl1+911
Good to hear the tires themselves are working well!
