#43 |
I've never looked for 305, but I can't find 325 or 345 . . . anywhere.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 06-08-2022 at 11:09 AM. |
#44 |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
I wasn't sure about fitment, and heard lots about rub on the inner rear fender with anything larger than 305's, so I just spec'd out the 1LE sizes for wheels/tires.
#45 | |
The Hoosier A7 is a really good DOT radial tire, but you would need to swap them on/off at the strip because they basically have zero tread.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 06-08-2022 at 11:48 AM. |
#46 | |
The 305/35/20 is a better match for the stock 245/40/20 front. The 30 will be shorter unless you changed the fronts to something else.
#47 | |
I just went with 1LE spec all the way around... according to the nitto site, a 275/35/20 (original rear) is 27.56 inches and a 305/30/20 is 27.24 inches. The 305/35/20 is 28.43 inches. I figured I was safe mimicking the 1LE sizes... it drove me nucking futz looking at all the different options and eventually just rage ordered something safe. Now that you mention it, the 285/30/20 may be 3/4 inch smaller in dia than the 245/40/20's... so back stayed about the same dia and front may have gotten smaller ![]() I had just removed my wheel/tire combo from my sig trying to clean it up Guess I'll put it back.
#48 |
Just went out and measured. The 285/30/20 fronts are smaller in dia by about 1" than the 245/40/20, but I think with the addl width, they had to get smaller in dia to clear the strut. In any case the stock rear 275/35/20 and 305/30/20 are really close in dia.
#49 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
#50 |
I didn't want to run the 275-35-20 as it is shorter then the 245-40-20. I still like the big tire look, I've never had a rub on my 305-35-20s. They just fill out the fenderwell much better. Not into the short tire look.
#51 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
[QUOTE=wnta1ss;11185356]Here's what Chevy put for the front tire sizes in the regular SS and the 1LE (non-driven tire circumference). Note how the 245/40-20 F1 runonflat was listed as 2164 mm circumference, then the 285/30-20 F1 Supercar 3 was listed as 2123 mm circumference. Rears list the same for both, but really they are not, the 305/30-20 is slightly shorter than the 275/35, and makes the speedo read a little higher in my experience. Screenshot of stock SS vs 1LE below:
Attachment 1101202[/QUOTE 285 35 20 = 27.9 inch diameter 275 35 20 = 27.6 inch diameter 245 40 20 = 27.7 inch diameter 305 30 30 = 27.2 inch diameter 285 30 20 = 26.7 inch diameter Last edited by lt4camaro; 06-10-2022 at 08:46 AM. |
#52 |
the 275 35 20 is 27.6 inches in diameter, the 245 40 20 is 27.7 inches in diameter. the 305 35 20 is 28.4 inches in diameter, that tall of a tire should rub... lucky you they do not.
#53 |
They don't rub if you relocate the harness on the driver side rear.
#54 |
#55 |
I think laynlo put them on 9.5" wide rims too, instead of 11" wide, so maybe that tucks it in a bit.
#56 |
A skinnier wheel doesnt have too much of an affect on the tread width, but does on the sidewalls. I believe it also makes the tire a little taller. Back space is critical to keep the tire/wheel out and away from the inside lower front section of the wheel house.
