Old 04-15-2021, 12:16 PM   #43
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Camaro1973 View Post
You don’t need e85 or 93 with meth.
This is on 93 w/ roughly 14lb boost.
This dyno jet uses an unspecified SAE correction factor whereas Hennessy uses the standard SAE correction factor
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-15-2021, 12:19 PM   #44
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Granted this is an A8, but this will give you some food for thought
LT1: SAE certified at 455 hp at the flywheel. Go google what SAE certified means, if you dont already know.
396 rwhp baseline.... ok so we are looking at 12.96% drivetrainloss... ok cool
Throw bolt ons on... we are now at 480 rwhp. Drivetrain loss is the same.. only did engine work. A little basic algebra would ballpark us at 551 flywheel horsepower
Next we install a converter... fun stuff happens. Now at 460 rwhp. Didnt do any engine work... so we are still at 551 hp at the flywheel. Again... some basic math here will show a 16.5% drivetrain loss.
Did I mention this converter was locked up as well?
Old 04-15-2021, 12:26 PM   #45
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This dyno jet uses an unknown SAE correction facture factor whereas Hennessy uses the standard correction factor
LOL what! That is the dumbest thing i've ever heard on here. I'm sure you can call them to give you the science behind their dyno.. lol. Between you and ZX-10 you should both become salesman for henneseey and elite engineering.
And BTW Hennessey is one of the ones who posts their dyno numbers in STD... unreal.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 04-15-2021, 12:29 PM   #46
Flexhorn
Drives: A10 ZL1
I’m at 824 Rwhp. I have Rotofab, cam, headers, lower pulley, 2650, 103 TB, and I replaced the rear axles with 1500hp rated. I’m on 93.
Flexhorn is offline   Reply With Quote
Old 04-15-2021, 12:31 PM   #47
JSH
JSH's Avatar
Drives: '20 ZLE
LOL what! That is the dumbest thing i've ever heard on here. Between you and ZX-10 you should both become salesman for henneseey and elite engineering.
SAE:
"SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque.
STD:
STD is Another power correction standard determined by the SAE. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard."
The first problem with quoting SAE is that there are at least 3 different SAE testing procedures but Dynojet does not distinguish them. The new SAE J2723 is actually not a new set of correction factors, it is simply a new procedure for using the existing factors (J1349 and J1995) used by automotive manufacturers but likely not by performance shops.
2020 ZL1LE A10.
Old 04-15-2021, 12:38 PM   #48
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
SAE:
STD:
This here "The first problem with quoting SAE is that there are at least 3 different SAE testing procedures but Dynojet does not distinguish them."
Is complete nonsense. What you posted above is exactly the conditions that are corrected when SAE/STD are used on a dyno.
