Old 06-27-2024, 04:26 PM   #43
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
Originally Posted by travislambert View Post
Absolutely! Be sure to check your car and order the studs if you need them.
Many of the 6th Gen Camaros come with the studs from the factory. I've owned four 6th Gen Camaros. Three of the four came with the studs in the thermostat housing. I'm not sure why some have them and some don't, but that's the reality of it.
The OEM studs are somewhat expensive for what they are. To include the studs with every kit would unnecessarily inflate the price. By offering the studs separately, it helps to keep the base cost lower.
That's interesting! I did look them up and was kinda shocked at how much they were!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 06-27-2024, 07:48 PM   #44
TurboC3
TurboC3's Avatar
Drives: 23 ZL1, 08 C6 vert, 70 Skylark GSX
I know this thread is a little old, but here's a nice guard solution to protect the thermostat housing in the event of a supercharger belt failure.
https://www.udaddy.com/products/gen-...-housing-guard
Attachment 1153239
Thank you, just ordered one! Much better option for me.
TurboC3 is offline   Reply With Quote
Old 06-27-2024, 11:50 PM   #45
Caerus
Caerus's Avatar
Drives: 2023 Camaro ZL1
Thanks again for bringing this up. Nice solution for a potential problem. My ZL1 has studs, so really easy install.
2023 Camaro ZL1 6MT Summit White
Caerus is offline   Reply With Quote
Old 06-28-2024, 07:02 AM   #46
travislambert
Drives: '17 ZL1
The biggest issue is volume. Over the life of a product, you might only sell 100 of somethinglike this. You have to be careful not to compare the pricing to something that is mass-produced. Not to mention, literally everything cost so much more to make now vs just 4 years ago.
Places that offer CNC machining charge a premium for small batches because it takes so long to setup tooling paths, etc. A volume of 100 gets the price down quite a bit, but yeah, it's still expensive. There's also the risk when you have 100 made that you might only sell a portion of them.
travislambert is offline   Reply With Quote
Old 06-28-2024, 01:56 PM   #47
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I think the guard being sold is a cool solution to a potential issue without a doubt, but running a plastic housing as a whole like the factory outfitted these cars to do is an impending issue as a whole which should be dealt with.
I prefer a billet unit offer a plastic because billet won't crack the same way a plastic one would under normal driving conditions and especially under track usage.
758 HP/ 804 TQ
Old 06-28-2024, 02:54 PM   #48
Broooster
Drives: Sharkskin Metallic ZL1
Billet housing in the future, once my warranty expires. This guard should work great until then. I would hate to give GM a stupid reason to void warranty work because of a different thermostat, and you know they would try.
Broooster is offline   Reply With Quote
Old 06-28-2024, 03:20 PM   #49
travislambert
Drives: '17 ZL1
Personally, I was nervous about using an LS-based aluminum housings on an LT-engine. The geometry is quite a bit different and I've heard of folks having issues with their thermostats after installing them. I haven't seen it personally, but the guys at Katech have and they don't use the aluminum LS housings on LTs anymore. I've had multiple engines built by Katech. They explained the details of the LS-LT thermostat mismatch issue to me, but honestly I don't recall exactly what they said, and I don't want to misquote them.
If someone would make an aluminum LT thermostat housing, that could be a cleaner end result than the guard but more effort to install. The guard solves the problem and maintains the OEM thermostat. To me that's a win-win, but to each their own.
Old 06-28-2024, 05:04 PM   #50
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Here is my Too High PSI billet housing. Top notch unit.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 06-28-2024, 09:54 PM   #51
Thank you for the tip, Sir. I ordered one and will post about my experience. Had to order the studs, too, because my thermostat housing came with bolts instead of studs...
Old 06-28-2024, 10:16 PM   #52
Old 06-29-2024, 10:15 AM   #53
ZLRob
Super Stock
ZLRob's Avatar
I don't see how geometry is an issue on the thermostats so I'd really like to hear what Katech has to say about that. I used an AC Delco factory GM 186* thermostat on initial install and it has been working just stellar ever since. I just made sure coolant was up to level, vehicle comes up to temperature proper temperature, and fans are working and everything just works.
If people have been having issues it most likely has been due to thermostat brand issues because I believe a lot of people use Motorad and similar knock off brands those have been known to be made with inferior components and be faulty right out of the box. All for the sake of trying to run a 160* or 170* temperature which is why I went factory Corvette temperature on mine from the LS7.
758 HP/ 804 TQ
Old 07-04-2024, 10:53 PM   #54
So I installed this guard today, see the pictures below. Easiest installation ever despite having to replace my bolts with studs I ordered with the guard. Fitment is absolutely perfect and the part looks OEM. Another potential bullet dodged
(Yes, my engine bay isn't clean. I'll take care of that later.)
Old 07-07-2024, 07:23 PM   #55
travislambert
Drives: '17 ZL1
Here is my ZL1 1LE with the thermostat guard. The engine has the Magnuson 2650 with a 92mm upper pulley (slightly larger than the standard 90mm upper pulley).
Name:  Thermostat Guard 92mm Upper 1024x768.jpg
