#43 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
That might help but the original hose on my car looked like it suffered the dreaded oil drip from the under torqued oil pan bolts.
#44 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
#45 | |
I’m also going to add that if/when you check the torque of the pan bolts, check the oil cooler line going into the side of the pan. You won’t regret it. I’ll have to dig that spec up too. I don’t recall if it was the same as the pan. EDIT: this number sounds right for the cooler bolts. This was faster than pulling out the service manuals. https://www.camaro6.com/forums/showthread.php?t=573013 One more thing, I had to drop the cover under the engine to get to the front pan bolts. You know the one with 300 screws/bolts holding plastic parts in place?
#46 |
Thank you sir! Very helpful info!
I'll put it to good use the next time I'm under the car-
#47 |
![]() Drives: 2023 Chevrolet Camaro LT1 RS Join Date: Sep 2023
Just had the same problem in my 2023 LT1. Bought it new over a year ago, it now has just over 26k miles, bone stock. Took off from a green light and happened to glance up and notice an unbelievable amount of white smoke coming out of the exhaust, and still halfway tried convincing myself it was because of how cold it was…
It definitely was not from outside temp. The dealer luckily fixed it under warranty [praise Jesus!] and told me it was the same hose part that had been cut, without mentioning how common this problem is. Additionally, my water pump failed around 20k miles. I carefully broke in the motor for the first 1,500 miles, so I know these issues weren’t due to a lack of tender love and care… Thank you to those who shared personal experiences, part numbers, and pictures!
Sullins
#48 | |
Drives: Camaro SS Join Date: Aug 2023
Mine broke this past summer. Mine also a 17. Over 70k miles. Dealer said its a normal wear item. I had them replace other rubber hoses along with my belts at the same time. |
#49 | |
#50 | |
Damn I got 7 years and 73k miles out of my hose. |
#51 | |
#52 |
![]() Drives: LT1 Join Date: Apr 2024
This is interesting. Maybe a fuel/oil safe hose would be an improvement, if leaking oil from the pan is the cause?
Or delete the factory water-to-air cooler? It looks like Improved Racing amd Hawkes Motorsports offer components for this. $$ though |
