Old 03-18-2021, 06:11 PM   #43
20Bluezl1
Originally Posted by LiqTenExp View Post
Sorry not able to check car this week. I can't imagine both of those should be populated. I would have done the V8 one unless I blindly followed instructions. It should be very easy to tell which is the correct one... pull it one at a time and see which one causes the JMS to not light up! That is the right one to replace LOL
I pulled the F35 and f46 and the JMS light was still on. Also does that light stay on all the time?
Old 03-18-2021, 06:24 PM   #44
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
It may take some time to bleed down and not go out instantly.
Old 03-18-2021, 08:47 PM   #45
20Bluezl1
Car is been off for 2 hrs and light is still on. Is that normal?
Old 03-19-2021, 09:49 AM   #46
ZLE dude
Drives: '18 ZL1 1LE
I'd think it would have went out by then. I've never tried killing my JMS after powering it on (just wired everything up and then hooked battery back up) so I'm not sure what to tell ya. I definitely changed out F35 from a 20A to a 30A fuse, but that was it.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 03-19-2021, 01:50 PM   #47
20Bluezl1
I changed it out also just wondering if anyone has checked to see if the light turns off or it stays on all the time.
Old 03-20-2021, 07:35 AM   #48
20Bluezl1
Nobody with a JMS knows if the green lights stays on all the time?
Old 03-21-2021, 03:27 PM   #49
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Yeah it stays on for a minute or two and then the power times out (like your running lights or parking lights).
CW3SF is offline   Reply With Quote
Old 03-21-2021, 05:50 PM   #50
JasonSB
Drives: 2018 ZL1
Mine is on all the time.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
JasonSB is offline   Reply With Quote
Old 03-21-2021, 06:45 PM   #51
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I would imagine that if you were to leave trunk open and let car go to sleep that it should turn out upon inspection (and not triggering anything to wake up in the car). I cannot imagine that the car leaves power to FSCM all the time. I would normally help answer all these questions but my car is still asleep for the winter and I'm not home to look at it. Next week I will look at it when the cover comes off.
Old 03-21-2021, 06:50 PM   #52
20Bluezl1
Thank you you might have a point I been checking it with the truck open, but again even with the truck open the truck light goes out after a while. I'm just wondering why does it stay on in my situation.
Old 04-24-2021, 08:20 AM   #53
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Did anyone ever find out if it is the F35 or F46 fuse on a 2018 ZL1?
According to the GM service manual the F46 goes to the fuel pump driver module (red/purple wire) and already has a 30Amp fuse in it.
Edit:
I can confirm it is the F46, just checked it with my Ohm meter.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 06-21-2021, 09:36 PM   #54
Vileintent
Drives: 2017 Camaro ZL1 A10
LiqTenExp, thanks for posting your approach and pics. Love the idea of depinning vs. cutting.
I can't seem to get the lock out of the connector. Can you point out two outer tabs you said to push out?
I tried poking at these spots but it didn't want to come loose and I didn't want to break it.
2017 ZL1 Black, A10
Build: Magnuson 2650R, 103NW Throttle Body, Rotofab Big Gulp, Kooks 2" headers, Catless, AWE Touring exhaust, JRE Smooth Idle Cam, Katech Oil Pump, Elite Catch Can, JMS Fuel Booster
Vileintent is offline   Reply With Quote
Old 06-22-2021, 06:29 AM   #55
ZLE dude
Drives: '18 ZL1 1LE
You're certainly prying in the right spot. If I remember correctly, you just need to pull the white tabs out towards the sides on the ends where you're poking around. Now you have to pull that white part out as far as it will go first. The white part slides out of the connector like 1/8 to 1/4" then you have to lift up the back of the little white tabs on the ends where you've pointed and it should slide out the rest of the way.
Here's the connector from the back side from his first post in this thread. I've pointed at the part that locks it in from sliding out on both sides. That's what you've gotta pry out to unlock it completely.
Old 06-22-2021, 08:06 PM   #56
Vileintent
Thanks. I'll give it another shot.
2017 ZL1 Black, A10
tms, xxx zl1
