Old 09-18-2020, 01:53 AM   #43
Bricks
Drives: car
Originally Posted by themassicator View Post
How did you mount them to the metal around the trunk? Any concerns with water getting in that area?
Interested as well. But I always get a ton of water in here after I wash the car.
Bricks is offline   Reply With Quote
Old 01-31-2021, 05:39 PM   #44
NotFast
Drives: 2021 LT1
Old thread bumped... I replaced my junk filament rear bulbs with these iJDM 7440 bulbs and mounted them with high temperature tape just like the pictures up thread. I'm not sure if they will stay dry or not, and don't have a solution for that yet - I'm considering some sort of shrink wrap where the iJDM male plug meets the OEM female socket but I'm not handy enough to know if that would be sufficient.
(yes it's snowing in Chicago right now )
https://www.amazon.com/iJDMTOY-No-Hy.../dp/B00OPEFLPG
NotFast is offline   Reply With Quote
Old 10-21-2022, 10:43 AM   #45
ls1smokedu
Drives: 2020 Camaro 2SS
I just ordered the iJDM ones linked in here - going to try them this weekend. Is anyone having any problems with them? It says it doesn't stay lit and doesn't interfere with the backup camera - does it cause battery drain? Winter is coming here soon and the car will possibly sit for a week or 2 without being started.
Thanks!
ls1smokedu is offline   Reply With Quote
Old 10-21-2022, 02:12 PM   #46
ls1smokedu
Update - the ones from Ijdmtoy work! They don't stay on and don't cause the backup camera to stay on. All the others I tried had both issues
Old 10-24-2022, 10:51 PM   #47
NotFast
Drives: 2021 LT1
I'm not gonna re-read this thread and see what I saiw, but...
Yeah it's that resistor pack that really does the trick. I tried to solder a $0.10 resistor onto another set of bulbs and but then I couldn't get it into the hole properly.
The only thing you need to watch out for with the iJDMToy setup is that the resistor can get pretty hot (although it's not like you leave those bulbs on for very long). I used VHB tape to secure them to the body.
Old 10-27-2022, 01:51 PM   #48
tommy21LE
Drives: ‘21 2SS 1LE A10
The iJDM setup was junk, when washing the car water gets in there and basically shorted out/fried the resistors and wires. I had the best luck with Diode Dynamics bulbs/ vampire tapped their resistors and zip tied them out of the way. Looks great and bright as hell
tommy21LE is offline   Reply With Quote
Old 10-27-2022, 02:42 PM   #49
tommy21LE
https://www.diodedynamics.com/backup...maro-pair.html
Old 10-28-2022, 01:34 PM   #50
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
If you are going for the splicing route, you could also do with a small resistor rather than a hyper-flashing resistor. Again you don't need to go very low-resistance; the problem is fundamentally different from what causes hyper-flashing for LED turn signals. I would imagine a 100-ohm 3W resistor should just cover about any LED bulbs on the market.
With some heat shrink and wires, you can make a resistor that you can splice into the wires and it will do the job just fine.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
