Old 03-06-2019, 02:36 PM   #43
raflyer
Drives: 2014 Cadillac ATS 2.0T
The thing about the HPFP, it only becomes an issue when you start going lean from commanded AFR. Its a balancing act between Inj duty cycle and fuel pressure. Cooper knows. Safe estimate is 400-420hp If you add meth its higher. I got my LPFP from 52-54 up to 70-75 and it made absolutely no difference in the HPFP psi falling off. So you either need a cam change or new HPFP when you start going lean without meth. Eventually as HP grows, HPFP, LPFP will both need upgrades.
raflyer is offline   Reply With Quote
Old 03-07-2019, 10:24 PM   #44
dekes1
Drives: Camaro like
Originally Posted by Zzsteve View Post
Just installed our flex kit on an '18, and it works perfectly.
we have had the kit installed the exact same way on a 16 and 17 since last year, and neither work. i took apart the 17 today to double check all of my wiring, and its all correct, it just flat out doesnt do what its told :(
Have you tried swapping an ‘18 e80a into a ‘16? Is that even possible with different service #s?
dekes1 is offline   Reply With Quote
Old 03-13-2019, 02:41 PM   #45
Austin_504
Drives: 2016 Camaro RS 2.0t
^This^
HD Cooling and Brakes, Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back w/ Quad Tips.
Austin_504 is offline   Reply With Quote
Old 03-13-2019, 04:03 PM   #46
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Different OSs in the 18s.
Old 03-13-2019, 06:23 PM   #47
DarkFangz1100
Drives: 2016 Camaro SS
There's two different ECU's for the 2016...one discontinued and one that isn't...How to tell the difference other than looking physically I have no clue....However, I also think that the late model ECU could potentially have the support
However, if I can find a salvaged car here locally I'm planning to rip out the ECU and flash it to my car's setup and see if it's a direct plug and play with a reflash.
DarkFangz1100 is offline   Reply With Quote
Old 03-16-2019, 08:52 PM   #48
dekes1
Drives: Camaro like
Been doing some research and came to the same conclusion you have - there is a new revision of the '16 ECU. Service # 12668437 is the new one.
Fortunately, the things are dime a dozen on fleabay, I bought one for $36 and also bought a 2018 E80A for $65 (only a single # for the '18s - 12687467). Pulling out the MDI and GDS tomorrow when i get a moment and intend to see what I can program. Going to start with the revised '16 first, and see if FlexFuel works, then moving on to hacking in the '18 if not.
Old 03-19-2019, 02:19 PM   #49
DarkFangz1100
Originally Posted by cooper1965 View Post
I wish I had someone local willing to experiment. I would like to explore swapping PCM's. Although I believe more needs to be looked at on the 16-17 PCM before being certain flex isn't possible. Again, if I had someone local, I could test a few theories:(
Lol, If I was still in Arkansas I'd come up Always down to make things better for the community
Old 03-16-2020, 12:59 PM   #50
v8sten
Drives: 2018 cruze
I Know, I know, its an old thread, but relevant to the info I am looking for.
ok new here but not to the car world. I dont have a Camaro but i do have a 2018 Cruze with the same E80A ECM. Being a turbo 1.4L, I pulled a log and it isnt running any timing or using any injector (11% IDC max). So I am curious on what pin I tie the Flex Fuel sensor into on the ECM. I have done this on Corvettes with the E38 ECM and have been successful. I was wondering if you know what pin to tie into on the E80A ECM?
v8sten is offline   Reply With Quote
Old 03-16-2020, 04:10 PM   #51
v8sten
Drives: 2018 cruze
Fairly confident its pin 70 on X3. You could also find one on a lot that was flex fuel from the factory, and double check. I believe the premier models are flex fuel from factory. I have a 2019 factory read on a flex fuel Cruze if ya need it.
Post it or pm it to me and ill run a comparison
Old 03-16-2020, 05:27 PM   #52
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
Great Project Cooper. I want to look into it sometime. W/M has my attention for the time being. We could crowd build a 500 hp drag car some day.
NFG M6 2T
Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel
Last PB
4.8, 13.2@106
wookwook is offline   Reply With Quote
Old 03-16-2020, 08:05 PM   #53
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Thanks, I was going to have flex fuel one way or the other when I bought my car, this Thread ensued.....
Its crazy going back to the beginning of this thread, and knowing how much information has changed on this platform in just over 1 year. .. Most notably, the availability of flex-fuel for Everyone.. It is my absolute honest opinion, on E85, the LTG will withstand more abuse, at a safer level, and actually last Longer, while making more power than an ALL things equal 93 octane car. So I am very glad for this recent development. Should be very first mod for anyone tuning, with E85 pumps locally available.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 03-16-2020, 10:36 PM   #54
v8sten
Drives: 2018 cruze
You will have to PM me your email. I can not post the file here, or in pm unfortunately.
Done did
Old 03-19-2023, 10:58 AM   #55
427
Drives: Camaro
Cooper are you still running your car with stock engine internals? I'm switching mine over for E85 with modified tune right now while also adding a slightly bigger turbo. With the stock parts my power starts dropping off after 4700rpm, I'm needing more rpm.
Kurt
427 is offline   Reply With Quote
