Old 12-06-2018, 09:04 AM   #43
JonD
JonD's Avatar
Drives: 2018 SS 1LE
There is a LOT of info going on here in power loss from headers that I can’t believe is being put out there... real world butt dyno vs. rollers? I’m sorry what... :shrug:
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 12-06-2018, 09:07 AM   #44
7speed
Drives: 21 SS
Originally Posted by Umbriel View Post
Agreed! I'll be there as soon as it opens back up to see where I am from stock which is 12.20 @ 114 mph. I expect to be 11.70 @ 119 now.
On stock tires 1/4 mi with same 60ft as my previous runs, I gained .2 and 3-4 mph with my tsp 1 7/8 w/cats .
Before that from rotofab only to tune and "e85" similar 60ft, I gained .4 and 5mph
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 12-06-2018, 09:18 AM   #45
Laststandard
Drives: 2018 1SS 1LE
With 1 and 7/8 header the engine produced no power (as in can't move the car) between 850 rpm and 1200 rpm till I put cats in the car. With 2" just off the cuff it would be 850 to 1450 RPM (going by increase in tube volume), that is um 80 percent of my DD performance, also know as "goes down the street".
Sounds like you had a tune issue more than anything else.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 12-06-2018, 09:24 AM   #46
Umbriel
Drives: 2016 Camaro SS
So I should be right on with that .5 and 5 mph guess. Thanks.
Umbriel is offline   Reply With Quote
Old 12-06-2018, 09:38 AM   #47
7speed
Drives: 21 SS
Forgot to mention I did get a retune once headers went on.
Hopefully I get another .5 and 5mph when I get cam installed this Feb
FBO, E85
11.1@123
Old 12-06-2018, 09:54 AM   #48
Umbriel
I would think so, maybe even more honestly.
Old 12-06-2018, 10:12 AM   #49
oldman
Drives: SS 6 speed of course
Dude, I'm talking part throttle driving, how is that going to show on a dyno?????
Old 12-06-2018, 10:13 AM   #50
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Seems like some of the posts yesterday regarding cats and m6 cars got deleted. Anyone else experienced issues without cats on an m6 car running stock TB and IM? Not an msd.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 12-06-2018, 10:13 AM   #51
oldman
Odd I have 2 inch headers and have none of those issues, I even have the stock plug wires still on there *gasp*
Sounds like the ported MSD is the majority of the problem with your issues honestly.
Do you have a M6? Cause with the cats... all works fine and dandy. The autos have a AFM valve for low speed backpressure and / or the auto are not as sensitive to low speed flow.
Old 12-06-2018, 10:18 AM   #52
oldman
I've only heard of this on an M6, and it is not only with LT, even CA and the full deletes have a strange harmonic. Some experience knock retard, I have not. But there is a low speed harmonic at low throttle settings say at 1200 RPM with ANY primary cat delete.
Old 12-06-2018, 10:21 AM   #53
CompleteStreet
CompleteStreet's Avatar
Drives: 2018 Camaro ZL1 A10
Give us a call on Kooks @ 610-628-2095- We will give you the best deal bar none!
https://www.cspracing.com/vehicle-pa...aders/headers/
CompleteStreet is offline   Reply With Quote
Old 12-06-2018, 10:36 AM   #54
6spdhyperblue
Drives: 2SS 1LE
I haven’t noticed any part throttle loss with cat deletes or catless 2” LTHs on a m6 I’ve driven. Definitely strange
Old 12-06-2018, 10:40 AM   #55
Umbriel
His problem is definitely MSD and/or tune related. Needing back pressure to run properly is a myth.
https://vpexhaust.com/exhaust-back-pressure-a-myth/
Old 12-06-2018, 10:52 AM   #56
RobbyBeefcake87
Ca pipes
This is what I was thinking, but I could be wrong. Is a tune necessary with CA cat delete pipes? I like them because they bolt on without cutting or welding and have o2 sensors. I'm just looking for tuneless bolt ons at the moment.
