#43 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
Mine has done this “wig-wag” feeling on a cold day with a little less air pressure in the rear with a passenger present. We were both “WTF” is that? All nannies were on in sport mode. At the track this week at 160mph it was rock solid...who knows?
#44 |
solid at 160...no brake yet
#45 |
Where the heck were all you guys when I started this thread. I never did figure anything out.
http://www.camaro6.com/forums/showthread.php?t=500793 Hate to see this happening to others, but at least I wasn't going crazy. Stock tires on the drag strip was where I first experienced it and then the uneven pavement during acceleration. Tried drag radials and it got worse. Is this an A10 thing? Don't seem to see the manuals chiming in other than the bog issues. |
#46 | ||||||||||||||||
#47 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
#48 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
A quick look at page 6 says “ Adjust tire pressures so that the front pressure is 2 psi higher than the rear pressure.” This can be another option.
https://my.chevrolet.com/content/dam...tion-guide.pdf
🔺22 RS E TRON GT
🔺21 Model S Plaid |
#49 | |
🔺22 RS E TRON GT
🔺21 Model S Plaid |
#50 |
Seems the 34 front and 32 rear solved the issue. Still have not moved the rear bar one link forward. Now I can get on it in 3rd and NLS into the next county without issues.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
#51 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
Noticed this today in mine, anyone figure it out yet ?
#52 |
![]() Drives: ///M3 Join Date: Nov 2016
Has anyone considered the wallowing could be caused by the tire grooves in the pavement?
#53 |
...and another one
#54 |
![]() Drives: 2019 F150 Join Date: Jul 2016
Running a stretched 285/35R20 all season on the back. Car usually slides controllable left and right all the way up to 80+ mph.
I suspect the back tires are spinning slightly faster than the fronts. |
#55 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I'm surprise to see this on a ZL1 1LE because it has the solid rear cradle mounts. I had the rear end kick out on my 5th gen and installing solid rear cradle bushings really tightened up the rear end. No wallowing either. I do have other suspension mods including a 1.25" rear adjustable bar.
#56 | |
🔺22 RS E TRON GT
🔺21 Model S Plaid |
