Old 11-06-2020, 11:05 AM   #43
Smoke-in
Drives: 2018 Camaro SS 1LE
So, going to install new half shafts soon. Does anyone know what the torque spec is on the 6 T bolts, CV to Diff.? And what to torque the big 36 mm axial nut at??
Smoke-in is offline   Reply With Quote
Old 11-06-2020, 05:24 PM   #44
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
The manual I linked in post #34 should give you that answer. It should actually be near the same section as the axle nuts if I remember correctly.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 03-16-2021, 10:56 AM   #45
Camaro Rules
Camaro Rules's Avatar
Drives: 2018 2SS Camaro
What size Socket is needed for the...Axle Nut? I see some say 36mm...I just bought a 36mm impact socket and it doesn't fit.
Thanks in advance!
Let the Good Times...Roll!
Camaro Rules is offline   Reply With Quote
Old 03-16-2021, 11:34 PM   #46
nprario
nprario's Avatar
Drives: 2017 1ss 1le HBM
I believe I used a 1 7/16 which is like 36.5 MM. A 36 did not fit mine either.
nprario is offline   Reply With Quote
Old 03-24-2021, 10:28 AM   #47
Camaro Rules
Thank you for the...information!
Guess...I will have to go buy...that size!
Have a good one!
