Old 11-26-2017, 04:46 PM   #43
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Glad your getting it handled. Those gaskets...I just don't know. Hope they work great. I'm working on getting my tune as well, I just installed the same headers a couple weeks ago.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 10-29-2019, 10:25 PM   #44
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
anyone have part numbers for the cometic and fel pro I cant find them,
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 11-02-2019, 11:34 PM   #45
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
17,18,25ft lbs, It does not matter... Those specs are for when you have the engine on a stand. You can not get a tq wrench on each bolt with the engine in the car and get a accurate tq spec anyway. Aside from that, It's not like you are torqueing the head bolt's where it is much more critical. tighten the bolts down from the middle out and it will be fine.
i had no problem getting to them. only use new GM gaskets torque from inside out 11lbft (132inlbs) then 17lbft. iv done 4 sets of headers on LS motors and 1 on the LT1 and torqued them to 20lbft and never had one loosen up.
Old 11-03-2019, 09:04 AM   #46
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
I'll be doing this install soon, and have a few questions for the experienced ones.
Does Kooks provide the header bolts, or did you purchase new ARP ones?
If you purchased ARP, which ones?...part number please.
How often do you need to re-tighten after heat cycles?
Has anyone used the locking ARP header bolts...good, bad, ugly?
Is there a heat shield that can be used with the Kooks?
If ordered with Cats, do the Kooks throw a CEL?
Thank you!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 11-03-2019, 10:42 PM   #47
JCunningham
Drives: 2017 2SS M6
i used ARP https://www.summitracing.com/parts/a...make/chevrolet 132inlbs then 20ftlb on new gm gasket. You should take it for a ride then re torque to 20. (mine have never loosened up and i dont use loctite.
headers dont come with heat shields but you should use heat tape DEI https://www.summitracing.com/parts/dei-010408
you have to tune for headers so you will get a light. until you do.
Old 11-04-2019, 08:03 PM   #48
OVRKLL
JCunningham, do you know if those bolts would work with Kooks Headers?
I don't know the flange thickness, but I'll contact Kook to find out...just wondering if you know.
Thank you for the links, I purchased the thermal tubes for the spark plugs, after seeing yours...good idea!
Old 11-04-2019, 08:22 PM   #49
6spdhyperblue
Drives: 2SS 1LE
Can anyone sell me one stock header bolt?
Old 11-04-2019, 08:31 PM   #50
JCunningham
Drives: 2017 2SS M6
im pretty sure kooks is 3/8" flanges.
Old 11-04-2019, 08:34 PM   #51
JCunningham
Drives: 2017 2SS M6
should be able to get on from your local GM dealer in a day or 2. under $5
Old 11-04-2019, 08:49 PM   #52
JCunningham
Drives: 2017 2SS M6
but i can see i still have them. you pay shipping.
Old 11-05-2019, 04:57 AM   #53
6spdhyperblue
Drives: 2SS 1LE
I’m actually going to the dealer today let me see what they say
Old 11-05-2019, 04:59 PM   #54
OVRKLL
Yup, Kooks emailed me saying it is 3/8" flange.
Thank you!
Old 11-05-2019, 05:32 PM   #55
OVRKLL
Has anyone tried these gaskets?
https://www.rockauto.com/en/moreinfo...435898&jsn=439
Says it meets or exceeds manufacturer specs.
They also have the OEM ones.
https://www.rockauto.com/en/moreinfo...435898&jsn=438
Trying to get all my ducks lined up prior to install of long tube headers.
Old 11-05-2019, 05:45 PM   #56
enzia35
Drives: '16 Garnet Red 1SS
Get the OE gaskets!
'16 Camaro 1SS
'18 Miata GT
