Old 12-21-2017, 10:10 AM   #43
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Originally Posted by RLHMARINES View Post
I think it was already discussed before that if you were to run this wheel tire combo on a regular ZL1 or SS 1LE, you would definitely need to trim the struts as shown in the pictures and set your camber to stock. You could gain your negative camber back by installing camber plates and use them instead of the adjustments at the spindle/hub area. As you adjust the top of struts in for max negative camber this leaves wheel clearance on the lower strut area.
Just to eliminate any possible confusion, I'm pretty sure the struts have not been trimmed in this photo. It looks 100% stock, but I think one could trim the strut and gain clearance for negative camber. The upper camber plates may be the better option for adjustment as you wouldn't need to trim anything. Maybe one of you guys that have these wheels on a mag ride car can confirm that please.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 12-28-2017, 12:02 AM   #44
fast4valve
@fast4vavlezl1@lt4_nation
fast4valve's Avatar
Drives: 2018 ZL1 1LE
ZL1 1LE wheels on ZL1 will they fit?
Finally had the chance to install my new wheel setup. I went with signature wheel SV501 with the same offset as a zl11le. The car is still on the stock alignment specs, and so far no issues with rubbing. It’s definitely cutting it close to the strut assembly. Anything more aggressive you would definitely need a 3-5 mm spacer.
(I’m also lowered on Eibach prokit)
fast4valve is offline   Reply With Quote
Old 12-28-2017, 01:53 AM   #45
Donjuan
Donjuan's Avatar
Drives: 2015 ZO6 stingray 3LZ Z07 package
Thumbs up Looking good
Looks Good
Donjuan is offline   Reply With Quote
Old 12-28-2017, 08:05 PM   #46
Tachitup
Tachitup's Avatar
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1
you car looks awesome ... thanks for sharing the photos
Tachitup is offline   Reply With Quote
Old 12-28-2017, 08:09 PM   #47
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
I've also test fitted the Z28 wheel (same size/offset) it will barely, barely fit with a street alignment. If the purpose of doing ZL1 1LE wheels is to look good, should be fine. If your purpose is to track your car, you'll need a 3-5mm spacer minimum if you're going to track align your car, which if you're going to run an R-compound tire and not track align your car...wtf are you doing?
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 03-15-2018, 02:52 PM   #48
ReefBlueCoupe
ReefBlueCoupe's Avatar
Drives: A few of each
https://uploads.tapatalk-cdn.com/201...a2e73769df.jpg
https://uploads.tapatalk-cdn.com/201...fd6ddaf037.jpg
https://uploads.tapatalk-cdn.com/201...8b7e7e1e5b.jpg
https://uploads.tapatalk-cdn.com/201...5aad0422eb.jpg
https://uploads.tapatalk-cdn.com/201...6ada9b8860.jpg
Bump - I saw where you said the offsets are the same as the ZL1 1LE, but I didn't see if you also used the same wheel size as the ZL1 1LE (assuming so based on looks) so to confirm, are those 19x11F and 19x12R?
Have you any complaints/comments about this setup since it's been a few months?
If you had do it over, would you change the offset a bit for more strut clearance vs running a spacer for track alignment specs?
I'm looking at some Forgelines in ZL1 1LE sizes and offsets (maybe a few mm toward the negative side in the front to negate the need for a spacer if changing alignment specs) and am gathering any and all info so I don't make a $6k mistake. I'l also be running the OEM ZL1 1LE tires. I may even consider 10.5" front and 11.5" rear to negate some of the headaches and also so the wheels don't stick out as much, but still perform and look killer.
'18 MBM ZL1 1LE
ReefBlueCoupe is offline   Reply With Quote
Old 06-08-2019, 10:08 AM   #49
WFO220
living on the edge
WFO220's Avatar
Drives: 2018 ZL1
dam i feel so confused now about wheels and tires
WFO220 is offline   Reply With Quote
Old 06-08-2019, 03:26 PM   #50
Markoz28
Drives: 18 ZL1 nightfall grey A10
It’s a tough one for sure. I’m about to attempt 325/30/20 on the rear of the ZL1 in the next few weeks. Just saving up for tires.
Markoz28 is offline   Reply With Quote
Old 06-08-2019, 04:29 PM   #51
Grumpy1
Grumpy1's Avatar
Join the club.....Lol
Grumpy1 is offline   Reply With Quote
Old 06-16-2019, 11:33 PM   #52
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
Looking forward to the results.
YoungFamous is offline   Reply With Quote
Old 02-02-2022, 11:46 PM   #53
Daddy_OZL1
Drives: 2020 Chevy Camaro ZL1
Anyone know the measurements on how far out the ZL1 1LE wheel/tires stick out from the rear fender
Daddy_OZL1 is offline   Reply With Quote
