Old 07-07-2018, 08:38 AM   #43
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I took a dremel and put a slight notch in my fan shroud. It took care of my maf connector hitting it.
Dysan911 is offline   Reply With Quote
Old 07-07-2018, 09:36 PM   #44
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Originally Posted by ProCharger View Post
Its in the tune. Not a big deal... just have it addressed and you'll be fine.
Are you just turning off that code or is the necessary adjustments made in the Driver Demand tables?
SC88 is offline   Reply With Quote
Old 07-08-2018, 05:04 PM   #45
oldman
Drives: SS 6 speed of course
The fan blade is 1/8 below the shroud (so I won't trim the shroud). I may trim the entry tube to the TB only along the bottom say 1/8 inch this will have a tendency to rotate the MAF portion of the tube away from the shroud.
All in all a MINOR quibble.
Old 07-08-2018, 07:47 PM   #46
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
I wonder if mine is in a different spot. I’m running the race IC and the piping is all metal, although I think the diameter may be different as well. I did have to remove a small corner of the fan shroud though.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 07-10-2018, 09:23 PM   #47
oldman
Mine is all silicone tube from intercooler to TB, wish I had your setup, I'm pretty sure mine is "newer", it is a fine setup, but the MAF pickup does need 5 degrees of rotation toward the engine, at least in my case.
