Old 04-11-2017, 11:30 AM   #43
slick3
Drives: Garnet Red - 20 ZLE
Originally Posted by SuperSound View Post
It's on autos too, think he was just stating like mine the wires are not close enough to belt to cause alarm, unlike the those with the real issue.
Yep so it has to be oil pressure sensor then but may have wires going to other sensors converging in that harness. Now why would oil pressure sensor trigger surging? Limp mode I could understand as the computer is attempting to protect the engine. May be just because the signal was fluctuating bad enough to cause the computer to put it in Limp mode?
That would be my guess yes. The wires that are frayed were actually the ones that are plugging into that harness that go down below it. Nothing above that connector in the picture posted.
slick3 is offline   Reply With Quote
Old 04-11-2017, 11:46 AM   #44
ctrlz
This is what I get for the oil pressure sender on a 6.2:
http://www.gmpartsdirect.co/oem-part...bC12OC1nYXM%3D
Old 04-11-2017, 11:48 AM   #45
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by slick3 View Post
Yep those are it. Seems like the only people with issues thus far were the 1LE cars. Mine being one of them
One was a 2SS, another was a ZL1...so seems random. May just come down to how that particular harness is installed.
Did you do anything about the frayed wires? Cut and splice? Or just tape up?
Old 04-11-2017, 11:58 AM   #46
slick3
I cut the screwed up section up out, spliced, soldered and shrink wrapped them... I had to cut some of the loom back to make it work. It was a serious pain in the ass. If I would have taken the belt off it would have been much easier. I had someone hold the wires from the bottom and I soldered from the top.
Old 04-11-2017, 12:01 PM   #47
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Really need to see a wiring diagram to tell what's using those wires.
Old 04-11-2017, 12:08 PM   #48
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Very interesting, thanks for taking the time to figure this out!
Old 04-11-2017, 12:13 PM   #49
ZXCamaro
Drives: Camaro
Thanks guys, I will be checking my new 1LE tonight for this and will report back. Mine was built 11/16.
ZXCamaro is offline   Reply With Quote
Old 04-11-2017, 01:39 PM   #50
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
You're very welcome and thank you guys for sharing additional information/diagram on that. This is why I love this forums!
This and the lose swaybar endlinks were the couple issues that I've had so for hopefully these will the only hiccups since I really love this car
IF you didn't already check this threadhttp://www.camaro6.com/forums/showth...10#post9641310 and torque your endlinks:
glamcem is offline   Reply With Quote
Old 04-11-2017, 04:08 PM   #51
ZXCamaro
Drives: Camaro
Guys. Just checked my 11/16 1LE car. My harness is not even close to that belt. I could fit my fist between the harness and that belt. Like I don't even need to wire tie it back to make more room. Thank god. But yeah it's no where near close. I can't really get a pic, but the wires come out of that plug and go straight down to that Y. Again well behind and below the belt. Almost parallel to the engine.
Old 04-11-2017, 05:04 PM   #52
glamcem
glamcem's Avatar
My car has a built date of 11/16, interesting
Old 04-11-2017, 05:07 PM   #53
SuperSound
SuperSound's Avatar
Makes me wonder if there was just some clip or attachment that was left off on some vehicles. Wish I could get a better pic of what is holding mine together.
Old 04-11-2017, 05:09 PM   #54
glamcem
glamcem's Avatar
very possible, a friend who owns a 17 2SS told me that there's a clip and his is not that close to the belt also
Old 04-11-2017, 07:23 PM   #55
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
12/16 SS 1LE here. Probably have an inch or so of room between that belt and the wires. GOOD CATCH glamcem!!!
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 04-11-2017, 07:56 PM   #56
zl1 canada
zl1 canada's Avatar
Drives: 2017 ZL1 coupe
not knowing what the wires are for, could be a 5 volt reference wire that are shared with other sensors and by shorting it out to the one next to it could be affecting the other sensors readings witch in result may put car into limp mode
zl1 canada is offline   Reply With Quote
