Old 06-05-2017, 09:56 AM   #43
Shaq74
Drives: Black SS 1LE
I'm here at the dealership getting this looked at now
Shaq74 is offline   Reply With Quote
Old 06-05-2017, 11:52 AM   #44
JusticePete
Drives: Camaro Justice
Originally Posted by KLR ZL1 View Post
So for those that have retorqued the bolts, is it still ok? Or did it come back? The reason why I ask is my ZL1 is making the noise now and was wondering. My local dealership by my house doesn't know anything about this issue. Was there any TSB issued yet to tell them what to do?
Unless you used LocTite and or a Nordlock style washer, the nut will work loose again.
JusticePete is offline   Reply With Quote
Old 06-05-2017, 11:54 AM   #45
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
I used a hint of blue loctite (just a hairline) and it seems to be holding fine
glamcem is offline   Reply With Quote
Old 06-14-2017, 11:18 AM   #46
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
I used Loctite Red and it lasted a month, but started rattling again yesterday...ARGH!
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 06-14-2017, 11:51 AM   #47
JusticePete
Nordlock washers are your friend.
Old 06-14-2017, 11:56 AM   #48
glamcem
glamcem's Avatar
Interesting, are you sure you torqued them enough? I used blue loctite (not a fan of the red as I believe it's a bit overkill). You may try using Nordlocks as mentioned above
Old 06-15-2017, 07:25 AM   #49
Tara Martin
Loves Camaros
Well, I tighten them as much as I can. I can't squeeze my old torque wrench in there for a reading, though.
It lasted about 5k miles on a drop of Loctite Red...I guess the rattle breaks the Loctite...
All I have to do is find those Nordlock washers, I guess.
Old 06-15-2017, 08:20 AM   #50
JusticePete
Fastenal will have them on the shelf.
Old 06-15-2017, 08:21 AM   #51
JusticePete
I am a suspenders and belt guy. Nordlock and LocTite!
Old 06-15-2017, 08:51 AM   #52
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
I'm thinking about being proactive myself - what size is needed? If you happen to remember... I'm sure I can figure it out easy enough, but thought I'd ask first.
RCF is offline   Reply With Quote
Old 06-15-2017, 10:36 AM   #53
JusticePete
12 mm
Old 06-15-2017, 11:35 AM   #54
RCF
12 mm
Thanks!!!
Old 06-16-2017, 09:34 AM   #55
Tara Martin
Loves Camaros
12 mm
Thanks Pete!
Old 06-16-2017, 02:29 PM   #56
HEAVENBOUND11112
HEAVENBOUND11112's Avatar
Drives: 2017 ZL1 Camaro
Talking Info on the clunking noise from the front suspension
Hi all! I'm new to the Camaro family (I'm a Mustang transplant) and just picked up my 2017 ZL1 this past Monday. I love the car so far but did notice right away after getting home the clunking in the front end. I will be checking the swaybar links today at my shop. One of the guys on here was asking about the proper torque for the end links. Here is a copy of the TSB listing those #'s.
CLUNK NOISE FROM FRONT SUSPENSION AT LOW SPEEDS
TECHNICAL SERVICE BULLETIN
Reference Number(s): PIC6276, Date of Issue: Mar 27, 2017
SERVICE INFORMATION
Chevrolet Camaro 2017 All All LT1, LT4 All
Involved Region or Country North America
Additional RPO/s: FE4 suspension
Condition Some customers may have a concern where they hear a clunk or rattle noisecoming from the front of the vehicle when hitting bumps.This can typically be heard while driving at parking lot speeds and hitting imperfections or speed bumpsin the road.
Cause This noise may be caused by the front stabilizer bar end link nut(s) loosening up which may cause the stabilizer bar end link(s) to make a rattle noise.This can happen on either/both side(s) of the vehicle.This noise can easily be mistaken forafront strut and/or strut mount assembly noise.
CORRECTION
Dealership technicians are to inspect the upper and lower stabilizer end link nuts for proper torque. The lower nut should be torqued to89 foot pounds (120 NM) and the upper nut should be torqued to 74 foot pounds (100 NM).If the upper nut is found to be loose, tighten the nut to spec and submit a Field Product Report per bulletin 02-00-89-002. (Canadian dealersshould refer to bulletin 10-00-89-006).
PARTS INFORMATION
No parts will be needed for this repair.
WARRANTY INFORMATION
Labor Operation
Description
Labor Time
8080278* Inspect and Torque Front Stabilizer Bar End Link Fasteners 0.4 hr
*This is a unique Labor Operation for Bulletin use only.
HEAVENBOUND11112 is offline   Reply With Quote
