Old 03-23-2017, 03:32 PM   #43
JeromeS13
Drives: 2017 1SS/1LE
Originally Posted by 1BlueSS View Post
I think something is wrong, cuss it just got hotter...
I would double check your fluid level...
Old 03-23-2017, 06:30 PM   #44
1BlueSS
Drives: 2017 Camaro 1SS
What size is that nut? The 17mm Allen socket I have won't fit. Actual socket may be too big. It's a tight spot.
2017 1SS Hyper Blue M6
1BlueSS is offline   Reply With Quote
Old 03-23-2017, 06:37 PM   #45
JeromeS13
Not sure and I can't look, since mine is at the dealer for a leak. This guy said he just removed the temp sensor:
http://www.camaro6.com/forums/showth...ht=trans+fluid
Old 03-23-2017, 06:41 PM   #46
JeromeS13
From doing some reading around, it looks like it may just be the 3/8" square from the ratchet head.
Old 03-23-2017, 07:25 PM   #47
slick3
Drives: Garnet Red - 20 ZLE
Its a 3,8 ratchet head for the plug, I used a tiny extension to get it out.
slick3 is offline   Reply With Quote
Old 03-23-2017, 07:55 PM   #48
1BlueSS
Trans fluid temp gauge not working ('17 SS 1LE)
Thanks guys. I'll check the fluid level and might change the fluid while I'm there. I'll check to make sure the lines are clear while the fluid is out.
