Old 03-30-2017, 06:33 PM   #43
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Just note that this (the 2.2kohm 1/4 watt resistor) wont work for blinkers. The resister used in reverse lights is just to compensate for the crappy reverse switch that leaks current when not closed.
The resisters on the blinkers are load resisters needed to deal with the hardcoded BCM that expects a certain load or it will hyperflash.
Old 03-30-2017, 06:41 PM   #44
keon718nyc
Yea i hear you on that. That resistor is working wonders on the Reverse LED is all i can care about. The blinkers colors suck and maybe soon someone will come up with a DIY for that too.
Old 04-18-2017, 08:38 AM   #45
tchowe
Drives: 2017 V6 Camaro RS
For those of you that have installed the Phastek kit, where did you position the heat wrapped resistor?
I installed mine last night and took some extra caution positioning it behind the light casing, but also to be between where water channels through the trunk and where water could get in through the small outside gap between the car body and light housing on the other side.
tchowe is offline   Reply With Quote
Old 04-26-2017, 06:09 PM   #46
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
Just got an email these are back in stock. Was able to order it before it sold out again.
Haole is offline   Reply With Quote
Old 05-22-2017, 10:55 AM   #47
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
I can't find these listed anywhere on the lighting section of Phasteks site. Anybody else? Edit: found it with a Google search. But says only for use on RS cars? Is that right?
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 05-22-2017, 12:29 PM   #48
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
You were probably looking for this kit:
http://www.phastekperformance.com/20...o-6-prled6.htm
How to install it:
See you!!,
Eos
Eos is offline   Reply With Quote
Old 03-28-2020, 06:53 AM   #49
Trackjunkie2020_1LE
Drives: 2020 2SS 1LE
Anyone else using the 2.2 ohm resistors with led bulbs? I want to put them in my 2020 Camaro. Post pics of how you wrapped the resistor on the bulb if you've done. How's the longevity? Is it worth it or just go with the more plug and play kit?
Trackjunkie2020_1LE is offline   Reply With Quote
