Old 04-12-2017, 10:10 AM   #43
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Originally Posted by n813ca View Post
At least your dealer looked at yours. The service manager at mine just said that it is normal
Sent from my SM-G935V using Tapatalk
Oh, I knew I meant to type something else.
The service guy also went to a 50th Anniversary customer car that was in the shop and tested it. It did the same thing. Then he went to 2 more V6s, and another SS on the lot, brand new. They all did it.
That's how he figured it was a design/manufacture problem - not something unique to my car.
00 Trans Ram is offline   Reply With Quote
Old 04-12-2017, 10:16 AM   #44
TJay74
Originally Posted by 00 Trans Ram View Post
Been having this problem (New Orleans, LA). Took it to the dealership. Told them that they needed to log the problem and send to GM, but that they probably wouldn't find a "fix".
However, they did run some tests on the car. Found out that the actuator motor that turns the dampers for the defrost are working properly. They even reset them and sent voltage to them independently of the A/C controls. Still happened.
They tried a few other things, none of which worked. Their conclusion (like ours) is that the dampers simply aren't sealing the airway closed. Without removing lots of parts, there's no way to find out. But, they did send the problem up the chain, to be combined with all of yours.
On another note - how the heck do you put any kind of "coating" on the windshield to prevent this? The fog is on the outside, not the inside. You mean that you put something on the outside of the windshield? How does it stay on past that first rainstorm and 500+ windshield wiper passes?
That was my thought as well, the condensate is on the outside not the inside of the windshield and is being caused by the blend door not closing fully for some reason allowing cold air to bleed up onto the windshield.
