07-25-2023, 06:51 PM | #43 |
Drives: ZL1, S2000 Join Date: Mar 2023
Reviving an old thread rather than start a new one. I know someone else posted on here that they got WARM as a reading on their dashboard. I have never seen anything above NORMAL even after driving for an hour about 70mph.
The manual states that NORMAL means the tires are ready for normal driving (not spirited) It also says that WARM means that the tires are ready for action and spirted driving. I guess my tires are never ready for cornering and spirited driving even in the summer? Or does this WARM reading happen only at the track? |
07-25-2023, 09:57 PM | #44 | |
Drives: 2SS 1LE Join Date: Oct 2011
Don't read too much into the tire temp, each tire is different and operates best at a different temp. A lot of racing tires will get pretty greasy pushing them hard when they get warm and hot. There's a hell of a difference between cold and hot, but the optimal range IME can be pretty narrow and you really can't chase that too hard.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
07-25-2023, 09:58 PM | #45 | |
Drives: 2021 2SS 1LE Join Date: Aug 2020
In short, if you want to see WARM in your DIC display (and take full advantage of your ZL1's capabilities), take your Camaro to the track! |
07-25-2023, 10:34 PM | #46 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
A warm reading per gm is about 117 degrees tire temp and warmer. Normal on the road or even on a mountain road will be just a normal reading. Now with good autocross tires like re71s, falcons or Nankangs my tires hit warm on my 3rd, 60 second run in 75-85 degree weather
07-26-2023, 07:19 AM | #47 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Driving it normally like you did its not going to triggered that temp notice. Only at the track or "track".
07-26-2023, 06:25 PM | #48 |
Thanks to JamesNoBrake,N Camarolina,VR Baron and WhiteMale for chiming in. Each of you provided really good info.
If I leave display on, I could see tires go from COLD to COOL to NORMAL (late spring to summer weather). So I thought, Ok, in this heat, I will definitely see WARM. But, I see it takes more than that and we can say my gauge is reading fine. Thanks. |
