Old 08-27-2018, 06:00 AM   #43
Goldfish
Drives: 18 2SS 1LE
Originally Posted by trohde78 View Post
Anyone looking for the kit to do this mod? I installed it and it works as described, but I didn't like the fact that it defaults to open at each startup, which requires the remote to set it back to the factory mode. Just looking to get a few bucks back rather than have this sit around, so PM me if interested.
Can you not wire it in either way? The homebrew version gives you two wiring options to make it default open or closed.
Goldfish is offline   Reply With Quote
Old 08-27-2018, 10:13 AM   #44
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
I would think that if it defaulted to closed, then the two options would be closed or back to the factory settings (Tour, Sport, etc). There would then be no fully open option.
trohde78 is offline   Reply With Quote
Old 08-27-2018, 09:19 PM   #45
Goldfish
Drives: 18 2SS 1LE
The relay interrupts fuse 51. On the DIY version, you can choose to wire it to either default to the factory settings (relay closed) or to NPP valves open (relay open) based on the terminal on the relay box you use.
Old 08-28-2018, 01:31 AM   #46
Crazed_1LE
Drives: 2018 Camaro SS 1LE
Is this the Mild2wild kit?
Crazed_1LE is offline   Reply With Quote
Old 08-28-2018, 05:56 AM   #47
trohde78
trohde78's Avatar
Nope. It's DIY based on the instructions in this post.
Old 08-28-2018, 06:39 AM   #48
Goldfish
Drives: 18 2SS 1LE
Ah. Some of the Amazon remote relays are single pole double throw, which lets you wire either way. This one might just be a single throw.
Old 08-28-2018, 10:45 AM   #49
Crazed_1LE
Ahh ok. I saw that Mild2Wild makes a Camaro Kit. I was wondering if their kit had the same issue as your DIY kit there.
IIRC, when I had the M2W on my Corvette, the valve position stayed the same until it was changed. So if you turned the car off with the valves open, they would be open when you started the car. If they were closed, then they are closed when starting up.
Old 08-31-2018, 08:59 AM   #50
trohde78
trohde78's Avatar
Yeah, this defaults to the "override" position, so you have to use the remote if you want to go back to the factory setting each time you start the car.
Old 08-31-2018, 10:24 AM   #51
DWR
DWR's Avatar
PM sent
Originally Posted by fastball View Post
Since 1967 kids all over America have bought the Camaro for the good old American way: loud and fun.
2007 Toyota Corolla S -- Traded
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled
2004 Silverado single cab 4.8l v-8 2wd -- Traded
2018 Camaro SS 1LE -- Current DD
1997 Jeep wrangler TJ sport — modded off-road toy/ camping
DWR is offline   Reply With Quote
Old 08-31-2018, 03:50 PM   #52
trohde78
trohde78's Avatar
Originally Posted by DWR View Post
PM sent
Replied
Old 09-19-2018, 08:34 PM   #53
tom's2005gto
Drives: 2016 2SS A8 Convertible
Originally Posted by camarorick View Post
Thanks for posting this
I just finished installing this mod, and have one thing to add... To avoid grinding a notch in your fuse box to hook up to negative, there is a negative connection inside
I've been trying to get a connector in to the ground you list in the fuse box. I can not get anything to remotely plug in or even reach a ground. I had to use an extended probe to verify it is a ground.
What style of connector are you using?
tom's2005gto is offline   Reply With Quote
Old 09-20-2018, 01:20 AM   #54
trohde78
trohde78's Avatar
From what I can tell, only the 2016's have connectors on all of the unused fuse locations. They must have deleted these on later models to save money. I couldn't get anything to stay grounded in that fuse location either, and had to put the ground outside of the box on my 2017.
Old 09-20-2018, 10:48 AM   #55
tom's2005gto
Form what I can tell, only the 2016's have connectors on all of the unused fuse locations. They must have deleted these on later models to save money. I couldn't get anything to stay grounded in that fuse location either, and had to put the ground outside of the box on my 2017.
I think I'll just drill a small hole in the side of the fuse box cover, use a grommet and route the wires through it. That way if I ever remove it, I can just use a small plastic plug to cover the hole.
