Old 11-20-2015, 01:35 PM   #43
Imp
Dodges all the cones
Imp's Avatar
Drives: Soon
I made a last-ditch request to a friend of mine in GM to ask the Camaro team for fitment numbers.
He did.
Now, we wait.
--kC
Imp is offline   Reply With Quote
Old 11-20-2015, 01:38 PM   #44
Whis
Drives: 2016 2SS Hyper Blue
He did.
Now, we wait.
--kC
You're the man!! Or woman. Thanks!!!
Whis is offline   Reply With Quote
Old 11-20-2015, 01:40 PM   #45
Imp
Imp's Avatar
Drives: Soon
*looks down pants*
Yep. Still a guy.
--kC
Old 11-24-2015, 09:06 AM   #46
Whis
Anything? ffs
Old 11-25-2015, 10:37 AM   #47
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
Back to wheel fitment / brake caliper clearance...
I was thinking... ATS-V comes with 4 piston Brembo. So I went onto ATS-V forum to see what they are using for winter wheels. They are using 18 wheels for 255/45/18 tires.
I know it will be different off-set for us, different overall diameter tires, etc... (255/45/18 is little too small, comparing to Camaro stock tires. Would be still drive-able, but wheel speed won't be correct. If 18" will work, I want to go with 245/50/18 all around if possible)
All I wanted to check was IF the 4 piston brembo will clear 18 or not. According to what I saw, it will.
I'm checking with a friend at Brembo, to see if Camaro's 4 piston and ATS-V's 4 piston are same (or at least dimension wise).
If 18" will clear, it will open up much more option for us when it comes to winter wheels/tires.
I know there are winter tires for OE stock tires size for Camaro, but I don't want to spend $1,600 just for winter tires, if I can avoid it.
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 11-25-2015, 10:45 AM   #48
jaymsu
Yeti's Daddy
jaymsu's Avatar
One question:
LTs can be ordered with Brembo upgrade, which I believe is to 4 piston front caliper, right?
Do all of them have to be ordered 20" wheels or can you order Brembo upgrade, while you keep 18" wheels? If that's allowed, that will answer 18" fitment question.
6000: 12/16/15
Old 11-25-2015, 10:58 AM   #49
Bassment
Drives: 2016 Red Hot 2SS M6
Originally Posted by jaymsu View Post
One question:
I don't think the brembo upgrade can be ordered without 20" wheels.
Bassment is offline   Reply With Quote
Old 11-25-2015, 11:02 AM   #50
Zack46
Zack46's Avatar
LT trims - You need the RS package in order to get the Brembo brakes.
SS trims - Brembo Brakes are standard
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 11-25-2015, 11:04 AM   #51
jaymsu
Yeti's Daddy
jaymsu's Avatar
Yeah... I just went onto Chevy.com to try building LT with Brembo upgrade. RS package had to be added.
Don't give up on 18" just yet. (or at least 19")
As I mentioned above, ATS-V clears 18" wheels with Brembo, so if they are same calipers (or same size calipers), we should be able to fit 18". (may need spacer, depending on off-set of the wheels)
6000: 12/16/15
Old 11-25-2015, 11:30 AM   #52
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Also there is a 20" black wheel option at $800, originally only for the 2LT but looking at the updated guide, perhaps for both LT lines. Either the WRS or the RTH wheels are required for the $485 HD Cooling/Braking option BUT the pricing post indicates it is available for $1285 absent WRS and RTH.
I expect there are some after market 18" wheels that will work but to find them will be a trial and error endeavor and a patient tire/wheel retailer.
Laborsmith
laborsmith is offline   Reply With Quote
Old 11-25-2015, 01:18 PM   #53
jaymsu
Yeti's Daddy
jaymsu's Avatar
Laborsmith
That's why I like Tire rack. They do that for us, and let us know what wheels fit, and what don't.
6000: 12/16/15
Old 11-25-2015, 01:33 PM   #54
laborsmith
Tire Rack can be conservative, which is why I like Discount. My local Discount Tire store will try wheels until one that fits over the calipers is found.
But if Tire Rack says a choice will work you can be pretty certain it will.
Laborsmith
Old 11-25-2015, 07:44 PM   #55
Bassment
I know. Well you don't actually need the RS package. If you get any of the 20" wheel upgrades they are available on the LT.
Old 11-25-2015, 08:49 PM   #56
jaymsu
Yeti's Daddy
jaymsu's Avatar
Ok... here is what my friend told me. ATS-V has 6 piston front (I don't know why I thought it had 4 piston) and still clears 18 inch wheels.
If 18 doesn't fit on Camaro, it would be due to other reasons, not the calipers.
6000: 12/16/15
