Old 12-31-2015, 09:11 AM   #43
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Originally Posted by 63falcondude View Post
I could be mistaken here but I don't believe that there are any engines built only for use with synthetics. If you have any source that says otherwise please share it. Keep in mind that I am no auto mechanic (by trade).
Ask yourself when was the last time you saw a high performance engine that did not have full synthetic factory fill. Why does the owner's manual say only synthetic. I'd suggest a little reading on synthetic vs conventional oil if you aren't familiar with the subject.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 12-31-2015, 10:07 AM   #44
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
I have to agree with Supersound. I have also done the MOTOMAN break in on motorcycles. I do not feel it is a necessary break in on these cars though. I am doing my first oil change this weekend be between 500-550 miles. I am going to use mobile 1 full synthetic because it meets the dexos 2 and not quit as good as the amsoil I normally run. Then at 1500 miles switch to amsoil. I keep my car normally under 4k rpm and once a day bring through the gears but not over 5.5k yet. At 1500 I will see what that feels like. Remember we are not breaking in race engines. These are performance engines designed to run over 100k miles. Race engines see 200 hours of operation or about 4-7k miles before they are rebuilt. Just my two cents and what I am doing.
drivingagain is offline   Reply With Quote
Old 12-31-2015, 10:07 AM   #45
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
I understand the differences between the two. Does the owners manual say only synthetic?
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 12-31-2015, 10:11 AM   #46
63falcondude
Originally Posted by drivingagain View Post
I have to agree with Supersound. I have also done the MOTOMAN break in on motorcycles. I do not feel it is a necessary break in on these cars though. I am doing my firt oil change this weekend be between 500-550 miles. I am going to use mobile 1 full synthetic because it meets the dexos 2 and not quit as good as the amsoil I normally run. Then at 1500 miles switch to amsoil. I keep my car normally under 4k rpm and once a day bring through the gears but not over 5.5k yet. At 1500 I will see what that feels like. Remember we are not breaking in race engines. These are performance engines designed to run over 100k miles. Race engines see 200 hours of operation or about 4-7k miles before they are rebuilt. Just my two cents and what I am doing.
Yea I agree, I was just questioning the statement that there exists a mass produced engine that is only supposed to run on synthetic. By "supposed to" I mean manufacturer recc.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 12-31-2015, 10:16 AM   #47
drivingagain
Yes chevrolet specs only to use dexos 2 approved oil. This is at minimum semi synthetic. My motorcycles spec castrol full synthetic 10w50. Anything BMW, AUDI, Mercedes requires to use full synthetic. Go see how much an oil change is for a BMW lol. This is also why I chan ge my own oil early. My 2010 BMW 535I they wanted 120 for an oil change.
Old 12-31-2015, 10:18 AM   #48
63falcondude
Aah, didn't know that. Is there no dexos 2 approved conventional oil? Also, does it say "recommended" or "requires"? I looked it up and found that it is a GM brand. Reminds me of Yamaha recommending "Yamalube" while anything JASO certified will work fine. It's amazing what stealerships charge. One of the reasons why I do all of the work myself.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 12-31-2015, 10:24 AM   #49
SuperSound
SuperSound's Avatar
Yep VW and most of the other German manufacturers require it too. As emissions/MPG requirements get tougher, more engines will be built for synthetic only since the tolerances have to be tighter and Dino oil will not cut it.
Old 12-31-2015, 10:58 AM   #50
drivingagain
Dexos 2 is just a performance grade that Chevrolet has set as their bench mark for oil quality. Actually Mobile 1 I believe makes the ac delco oil for gm but it is semi synthetic and mobil 1 is a full synthetic. Any oil manufacturer can design their oil and send it off to be tested to meet Dexos 2 qualifications though. The amsoil I will be running is Dexos 2 certified.
Old 12-31-2015, 11:14 AM   #51
63falcondude
Cool, thanks for the info.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 01-01-2016, 03:22 PM   #52
Camaro1LTBA
Drives: 2016 Camaro
I usually just read the manual and do whatever that says. Think I went at least 9 months or so until the light came on to change the oil for the first time. If I remember correctly on the 2014, the main thing I had to get used to in the beginning was to not use the cruise control and make sure I was varying the speeds and RPMs. Think that was it. Will read the manual when the car arrives from the dealership.
2016 Camaro 2SS Manual
Hyper Blue/Ceramic White
Nav, MRC, NPP, Black 5 Spokes
Escort MAX 360
Camaro1LTBA is offline   Reply With Quote
Old 04-06-2016, 01:34 AM   #53
Camaro Mark III
Drives: 2016 Black Camaro 2SS, 8Speed
Hm..it will take forever...
Originally Posted by Sledgehammer70 View Post
I have read what seems to be 1,000 posts around breaking in a V8 properly and making sure your car is running right from the get-go. Now, this is not my first V8, but my first already had 45K miles on it so I missed the boat. But this will be the highest performance car I have ever purchased.
So for this V8 here is the break-in process I will use.
Sledgehammer's Break-in Process:
1.) Drive for 1,500 miles (no crazy rev's, no burnouts, no racing etc...)|
2.) Oil change (empty, plus clear 2 extra quart of fresh oil)
3.) Drive fairly easy for the next 100 miles
4.) Have fun!
5.) Dyno it
Post your process below.
Thanks for the great info Right now, I have 90miles. I guess I will have 1500 miles in the middle of this month.
Satellite radio + Bose audio system + Engine/Exhaust sound are enough for now
Hope to enjoy the aggressive modes or high rev's legally soon too
Camaro Mark III is offline   Reply With Quote
Old 04-22-2016, 08:38 PM   #54
archer1965
archer1965's Avatar
Owners manual states AC Delco Dexos 1 Synthetic Blend. Page 326.
Break in: follow the owners manual recommendations. Design engineers know what they are talking about, it's their job and they are very good at it.
2SS Nightfall Grey / Black Rally Stripes / Sunroof
NPP / MRC /1LE Suspension / Nav / M6/ Xpel'd / CAI
archer1965 is offline   Reply With Quote
Old 04-22-2016, 11:05 PM   #55
mjw930
Drives: 2015 Porsche BGTS, 2016 2SS
Doing the same thing I've done for the last 10 cars. Drive it sensibly for the first 500 miles being careful to vary RPM's, not lug it and manage the heat cycles. Plenty of on and off power loading to make sure the diff, trans and rings are run it. I won't be worrying about max RPM's or max MPH but nothing extreme.
Change the oil and filter between 500 and 750 miles using this:
Then drive it like I stole it.
BTW, the oil that comes in the car is semi synthetic generic Dexos1 oil and that's what you'll get with the free changes. I don't plan on ever having the dealer change the oil. I can do a 10 QT change using that oil, with filter for $65.
mjw930 is offline   Reply With Quote
Old 04-23-2016, 12:04 PM   #56
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Attachment 790588
with the penzoil 2 bucks rebate per qt, i would think that cost would be about 20 bucks less.
