08-31-2022, 03:56 PM | #43 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
After my newfew drove my car. He dropped it down to second. I said just hit it. His expression said it all and he ran it up to 140. He said quote it just keeps pulling. I love the way it just keeps pulling. He says he wants to put one on his wifes scat pack. Just my experiences
09-02-2022, 08:23 AM | #44 | |
Comparing a Hellcat to a 6th gen is pointless far as traction...6th gen chassis is far superior. It's a known fact HC's don't hook. What does yours dragy 0-60, 0-100, 1/8 on the street?
2016 NFG 1SS A8
02-16-2023, 07:44 PM | #45 | |
I dont know what any of this was when up against the helcat. but back in march of 22 put down 0 to 60 of 2.93 0 to 100 6.34 1/8 th time is 7.01 at 106.73 Iv made quite a few improvements since then this is pump gas and meth Terrible traction on the street with a 1.8 60 ft |
02-16-2023, 09:42 PM | #46 |
Good time... my inferior Whipple does ok. Full weight car on 20's launching from 2nd gear on the street. No meth, stock cam, stock heads, stock rods/pistons, E60.
2016 NFG 1SS A8
02-16-2023, 10:36 PM | #47 |
Good times King
03-03-2023, 09:05 PM | #48 |
Drives: 2022 SS 1LE Join Date: Apr 2022
For what it's worth in doing a lot of research, the ring gap is false from some earlier posts.
The ring package is also new and thinner. Gen ll engines started with a 1.5mm top and 2nd ring with a 3.0 mm oil ring .Some later engines used a 1.2mm / 1.5mm / 2.5mm package. There has been a lot of misinformation out there about the new Gen V engines using thinner rings, so we asked our friends at Scoggin-Dickey Performance Center to measure the rings on the LT1 and they found the ring package at 1.2mm / 1.5mm/ 2.5mm, which is the same as the earlier Gen IV engines. Thanks to Nicky Fowler, Kurt Urban, and Keith Wilson at Scoggin-Dickey for clearing up this misinformation |
03-04-2023, 08:55 AM | #49 | |
2016 NFG 1SS A8
03-04-2023, 09:42 AM | #50 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
IMO, it has nothing to do with ring gap and everything to do with low octane. Taking a 11.5/1 motor that already needs 93 octane, and thinking you can still use 93 w/ boost (added compression) is the problem. E is a cheapest way to get some extra octane.
03-04-2023, 11:49 AM | #51 |
Meth is the cheapest way I made 930 on pump 93 and meth injection 20 pds stock cam heads
03-04-2023, 12:15 PM | #52 |
Agree on octane disagree about ring gap. If ring gap didn't matter piston companies like Wiseco wouldn't recommend .022-.028 ring gap for boost applications.
2016 NFG 1SS A8
03-04-2023, 12:44 PM | #53 | ||
03-04-2023, 01:11 PM | #54 | |
Also, you seem to know a lot and I probably shouldn't be on this thread since you are talking about the gap in the cylinder, that's over my head. I'm just a middle aged dude who does most of his own work in my garage. I have put a supercharger on a v6 Challenger, but I'm lost with all the tech talk. Cam lobes, tolerances, pressure this, pressure that. I guess I've been lucky with the mods I've put on my cars haven't blown up. Ha Against everyone's advice, I'm probably going with an ECS (probably do myself) and calling it a day. I have cai, cat delete, ported TB and x-pipe to the stock npp. So adding this sc is just the topping I'm looking for. Not dragging the car nor have I tracked it. However, I want to track this year, but never have. As they say-send it. Lol |
03-04-2023, 01:22 PM | #55 |
Nothing wrong with a ECS setup. And you are welcome to post here any time. I applaud you for doing your own work. Good luck with your build!!
2016 NFG 1SS A8
03-04-2023, 02:05 PM | #56 |
