06-23-2022, 03:31 PM | #43 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
My Kooks green GESI cats failed after two 20 minute sessions at the track, they were on the car for a year of street driving before that
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
06-23-2022, 04:07 PM | #44 |
I was told by a reputable tuner that Kooks green GESI cats are rated at 1400hp, but I wasn't told that by Kooks
06-23-2022, 06:51 PM | #45 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
06-23-2022, 06:59 PM | #46 |
Drives: 2019 ZL1 Join Date: Mar 2019
They were probably failing on the street before your track session. I would of never known if I didn’t scope them, or until they completely plugged or blew out. Mine didn’t melt, they just got all bent inwards.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-23-2022, 08:38 PM | #47 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
06-24-2022, 08:34 AM | #48 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
I contacted GESI with the numbers on the “green” kooks cats, they told me the were 500hp each. I’m not there, but I’ll look at the cats soon.
06-24-2022, 11:03 AM | #49 |
Based on the sound they make going down the track, I think mine are dead.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
08-02-2022, 12:44 PM | #50 |
Geoff
Both of mine are starting to fail. I contacted Kooks about it, they rate them at 425hp each. They came back with they failed because I am running E with a flex fuel sensor. We are still in discussions. I'm below 850hp at the crank.
08-02-2022, 12:50 PM | #51 |
I thought E reduced egt along with a cleaner burn. how does that make sense?
08-02-2022, 01:07 PM | #52 |
They are full of it. Mine failed on pump gas making 680whp. They all fail like this, they start to bend and once that starts it’s all downhill. I’ve got a box of 3 sets, all broken. Thankfully the gen 2’s are still holding up.
08-02-2022, 05:33 PM | #53 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
CSP has catted headers w/ G-power V2 Ultra Cats that can withstand 1700 hp. They're pretty sweet and perform better than the green cats (over twice the capacity). They are over $3k without any type of heat coating though.
08-02-2022, 06:29 PM | #54 |
It’s What’s on my car. Soon to be tested on 1k+ whp.
09-04-2022, 08:54 PM | #55 |
Drives: 1985 Oldsmobuick Join Date: Oct 2012
How do American Racing Headers with cats hold up to track use?
09-05-2022, 08:08 AM | #56 |
Drives: E92 BMW M3 Join Date: Oct 2012
They don't. The cats being discussed are the most capable, and this thread is about them failing. GESI Gen II cats seem to be the best so far.
J-Rod Built and Matt@FSP Tuned |
