Old 03-05-2018, 02:57 PM   #463
DangerZL1
Drives: 2023 Black ZL1 Auto
Are the 2018 models affected by this problem too?
Old 03-05-2018, 03:16 PM   #464
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
I haven't noticed this issue, but I haven't been using the A/C much. Once summer kicks in, I'll know for sure.
torqueaddict is offline   Reply With Quote
Old 03-05-2018, 10:10 PM   #465
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Yes http://www.camaro6.com/forums/showthread.php?t=515682
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 06-19-2018, 05:47 PM   #466
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
Originally Posted by TMasticTB91 View Post
Wanted to share a pic of the rubber baseboard idea for those interested.
I picked up a piece of Black Dahlia rubber baseboard from Lowe's for $1.89. The great thing about it is the curved lip that tucks perfectly in-between the dash and windshield. This piece is a bit lighter than the dashboard (in the pic the car is also has the sun) but it it's hardly noticeable and likely less so to those that don't know what it is. It's also long enough for two pieces, in case you want one for testing and one to "dress up" a bit.
It might not be perfect but hey, $2 fix and much easier than fanangling a microfiber towel into this space. I'll probably just keep it there unless I actually need to defrost.
I found it at Home Depot for only a little more money but it is working for me. The only issue I have is the outgassing of the vinyl on the area of the windshield. I can live with that as it does not interfere with visibility like the condensation does.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 07-04-2018, 10:11 PM   #467
Gen-X45
Gen-X45's Avatar
Drives: 2017 2SS Camaro
Here is a new twist... my 2SS did the window fog thing last night and my car wasn't even on. I was at the beach for some early fireworks. The car sat for about 4 hours, it wasn't humid at all. I live in So. Cal. and when I got back in to drive home, the window fog was there. It was cold to the touch, so it's not just the vent foam, it has to have something to do with the new R1234YF refrigerant. Something is leaking because just the cold air wouldn't do this on its own.
Gen-X45 is offline   Reply With Quote
Old 07-04-2018, 11:02 PM   #468
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
well at least your not breathing in 134a or r12
Old 07-05-2018, 04:07 PM   #469
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
No too bad...
TonyNo is offline   Reply With Quote
Old 07-05-2018, 04:23 PM   #470
JCunningham
Drives: 2017 2SS M6
does the vet pop out? would make it easier to make a cover
Old 07-05-2018, 04:36 PM   #471
TonyNo
TonyNo's Avatar
No, just that whole top part, but it's something.
Old 07-05-2018, 04:38 PM   #472
JCunningham
Drives: 2017 2SS M6
anyone know if it just pops out or are there screws holding that in?
Old 07-06-2018, 06:59 AM   #473
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
So ultimately, what can we do once our warranty runs out? I had my dealership do the service on mine, and it's still doing it (high humidity with temp set at 73 or lower).
If we've shown that it's a problem during the first 36/36, then why shouldn't we be able to pursue GM for a fix after our initial warranty runs out?
classicrockr is offline   Reply With Quote
Old 07-06-2018, 09:54 AM   #474
speedup
speedup's Avatar
Drives: 2017 2SS Convertible
Was there ever an official "fix" for this? my 2017 does this bad
2017 2SS, Hyper Blue, 8sp, NPP, MRC
speedup is offline   Reply With Quote
Old 07-06-2018, 11:00 AM   #475
Redlinez
Shifts under load
Redlinez's Avatar
I took mine in for the TSB for this issue and it still does it. They pulled the windshield and replaced it to perform the TSB. Next step would probably require dash removal which I'm not interested in. I'm a service advisor and have seen what can happen there.
22 Suzuki GSX-S 1000GT blue
Old 07-06-2018, 12:04 PM   #476
torqueaddict
How bad is the fogging? I ask because I've seen it happen once or twice and it's usually a small patch in the center just above the vents. It was not bothersome at all. Is the fogging that people are experiencing covering most of windshield, or just that center area?
