Old 12-09-2017, 07:22 AM   #1
Zap city
Drives: 2019 ZL1 1LE, MN6, SGM
Windshield fogging issue fixed on 18s?
Thinking about coming back to a new ZL1. Did GM remedy the fogging issue for 18s?
Zap city is offline   Reply With Quote
Old 12-09-2017, 07:28 AM   #2
motorhead
I would be interested in knowing this too as Im looking at the ZL1 also. Bump
Old 12-11-2017, 12:50 PM   #3
Thenotorious1le
Drives: 2018 1LE
I currently own a 2018 ss 1le, and they have not fixed this issue. Hope that helps.
Thenotorious1le is offline   Reply With Quote
Old 12-11-2017, 02:04 PM   #4
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
Have you contacted your dealers to see if there's been a TSB on it. Also I read on here that someone was having HUD problems and they were going to have to replace the HUD and someone else wrote in and told them to fix the fogging issue since they were going to have to remove the windshield.
Baldman is offline   Reply With Quote
Old 12-11-2017, 02:05 PM   #5
VQ35DE
Drives: 2013 / 2SS / RS / L99
Great. That figures.
VQ35DE is offline   Reply With Quote
Old 12-11-2017, 11:10 PM   #6
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Well that DOES suck.
They are oblivious to this issue.
Forget the TSB - use search to find that story. Spoiler alert: The TSB doesn't work.
Maybe some more NHTSA complaints will get their attention:
File a Vehicle Safety Complaint
LET'S GET STARTED!
COMPLETE this 5-step form -- it takes about 5 minutes
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 12-12-2017, 02:05 PM   #7
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
I was really hoping GM fixed this issue. I want to pull the trigger on a 6th.
JLSuperfly is offline   Reply With Quote
Old 12-12-2017, 10:35 PM   #8
camaro5
camaro5's Avatar
They don't all leak. Not sure of the variable, may be actuator mounting or travel.
If you can find what you want in stock, just check for defroster leaking cold air w/ ac on.
I may drive 2hrs to Miami to a large dealer (244 - 2018 Camaros currently in stock - 17 ZL1's / 45 SS's) to find a defect free unit.
k
STANDARD DISCLAIMER
Old 12-13-2017, 03:53 PM   #9
JLSuperfly
JLSuperfly's Avatar
k
From what I understand, the fogging occurs at the "right" temperature and humidity. I take that if it leaks, it is strong enough to feel it your hand?
Old 12-14-2017, 12:19 AM   #10
camaro5
camaro5's Avatar
You will feel it coming out of the defroster vent in AC mode.
In AC mode, the leaky defroster chills the OUTSIDE of the windshield and causes condensation build-up.
In OFF mode, the defroster seeps warm moist air and fogs the INSIDE of the windshield.
Higher humidity definitely makes both conditions more probable.
gh
STANDARD DISCLAIMER
Old 12-14-2017, 01:33 PM   #11
Baldman
Baldman's Avatar
Drives: None
Here's that thread I was talking about. Maybe one of you guys could send a PM to the Op and see if he had it done. http://www.camaro6.com/forums/showth...&highlight=hud
Old 12-16-2017, 03:10 PM   #12
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
Seems to vary from Car to Car. A friend has one. His barely dogs up if ever. Mine? Takes up half the damn windshield. I fixed that problem though by not using the AC in the morning and putting the windows down a bit. It’s fine then. Lol. And in the afternoon I can crank the ac up and no issues unless it’s rainy out. Some people just use a cloth and others have come up with covers that block the air. It’s annoying that GM doesn’t have a true fix... It’s been 3 years. However, it also doesn’t surprise me.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 12-18-2017, 07:13 AM   #13
Billabongi
Billabongi's Avatar
Drives: '17 SS 50th Camaro
Actually the TSB worked for me. I've only had the issue one time since having the TSB done and I was purposely trying to cause it. Even then it was a much smaller spot then it used to be.
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410
Billabongi is offline   Reply With Quote
