Old 10-15-2022, 09:59 AM   #407
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Looks like trans torque management. Did the max torque gear vs rpm table get reverted back to stock? Shouldn't need any suspension yet, lower the tire pressure. 21-23psi.
Old 10-15-2022, 10:43 AM   #408
cjperformance
cjperformance's Avatar
No. Double checked it just to make sure now that you mention it. 1-2 shift is set at 35 mph. Going to try dropping that down... To me... it seems close to right... but the ECU/TCM is funny that way if it thinks theres going to be an RPM overrun. I've seen this mostly in D mode with WOT downshift if I have the shift mph too high. This looks the same to me... just in 1st. I think this interplays with the
I'm thinking it's got to be either that or it just needs to learn that shift by doing that a couple more times. I'll just try dropping it down several MPH and just retry the next time, then creep it back up if its gone.
It may also have something to do with this table... but I haven't wrapped my head around it yet. I think it was this table that was discussed in another thread regarding rpm limits and not allowing enough torque. I think these values are triggered when the ECU thinks there's going to be an RPM limit overrun.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 10-15-2022, 10:48 AM   #409
cjperformance
I could have run more E last night. I was at E52 earlier in the day, but mixed down to E45. I was concerned that temps were going to drop more than they did and wanted to ensure I had plenty of inj overhead. As it turns out it clouded up and kept temps higher than expected. Not only that, but a pull where I start out in 2nd or 3rd... by the time I get to the top of 4th, IATs are much lower than what I saw last night and inj pw is riding the limit. Last night, with staging lane heat soak and longer pull, the IATs were up around 150F at the end... So I had plenty of inj overhead left. It started pulling timing too. I know that can be adjusted, but erring on the side of safety for now. Airflow lb/min and cyl airmass were dismal compared to a similar street pull. I didn't break 80 lbs/min and was below 1.3 g/cyl airmass. During tuning runs, a pull would have gotten me 85 lbs/min and 1.40 g/cyl, at least at top of 4th.
This is the first burnout since I did the trans tune. I don't do that kind of thing on the street. Before I had the trans tune, I had to really stab the throttle hard and keep feeding more throttle in to offset the torque limit per gear... So this time out I instinctively did the same, but no torque limits this time, and it ended up shifting into 3rd, which you can hear in the vid.
I'll probably raise the eqr to .82 instead of .80 for the next time as well.
Not sure how to embed this link so it actually shows a preview :/ Thought I saw others do that.
https://youtu.be/ptVyLKyn3ys
Old 10-15-2022, 10:59 AM   #410
cjperformance
Finally here is a side by size of Dragy and Timeslip.
1/4 mile was pretty darn close, but there was some difference in the 60'. Not much, but some.
Old 10-15-2022, 11:04 AM   #411
grampa_ss
grampa_ss's Avatar
What is the current 1-2 shift MPH set to?
I'd set the 1-2 shift to 31MPH.
Looking at the chart, it looks like the shift rpm for 1-2 is actually lower than the shift rpm for 2-3 & 3-4. Maybe show the log to Rick, get his opinion.
Also, I don't see you logging AFR. Definitely want that.
All that being said, you made good progress. Congrats!
Old 10-15-2022, 11:10 AM   #412
cjperformance
Thanks!
I'm logging Commanded and Actual EQR/lamba. It's in the second graph from the bottom.
Old 10-15-2022, 11:20 AM   #413
grampa_ss
grampa_ss's Avatar
That table (12073) is exactly like mine. You also may want to look at Engine/Fuel/Cutoff,DFCO/RPM limits/control method - Disable "Use Predicted Torque".
Old 10-15-2022, 11:42 AM   #414
grampa_ss
grampa_ss's Avatar
I agree with what you said earlier...Wheelhop caused the 1-2 hiccup. I'm sure you did but just in case...be sure to turn the nannies off by pressing the traction control button for like 10 seconds. Do the burnouts in manual mode. I put it in 2nd.
Old 10-15-2022, 11:44 AM   #415
cjperformance
Rick got back to me really fast. I won't speak to the actual changes out of professional courtesy, but based on the changes he made... I was partially right about the 12073 torque limit/rpm/gear with the limiter. He changed a few other things too.
There's still a few test n tune type days left in the season. I'll try to get out there and retest.
Old 10-15-2022, 11:48 AM   #416
cjperformance
Yep, yep Exactly like that. All nannies off, tutd mode 2nd gear. Only burnout "problem" was driver error letting it shift to 3rd. Was going to burn out for 3-5 seconds around 45-50 mph and it went to 60 quickly and upshifted... still got some tire smoke going, but could have been better. oh well. Lessons learned.
Old 10-15-2022, 11:49 AM   #417
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Ok, in a rough order I’d do:
Cradle lockout
Diff lockout
Rear toe bars
All 3 sets rear control arms
Get alignment done (important!)
Now break out the plastic and start spending!
Old 10-15-2022, 01:22 PM   #418
KingLT1
KingLT1's Avatar
I meant in the TCM under torque management but yeah that table looks like it needs some work.
Old 10-15-2022, 01:52 PM   #419
cjperformance
TCM torque mgmt is good. I understood what you meant. At some point I just realized about the other table too.
Old 10-15-2022, 02:37 PM   #420
KingLT1
KingLT1's Avatar
Ok..the ECM table I just set to 1200 across the board that way if you accidently hit limiter, it doesn't cause any limiting when you shift the next gear.
