Old 01-07-2026, 09:32 PM   #29
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by bishopts View Post
Seems like a pretty solid setup, kinda heavily focused on forced induction high hp builds.
100%
Old 01-07-2026, 10:01 PM   #30
clj94104
Drives: Camaro ZL1
I suggest looking into the Motion Raceworks vented top loader catch can
clj94104 is offline   Reply With Quote
Old 01-19-2026, 07:50 PM   #31
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
How much fluid are you seeing in your CC, and how much vapor are you seeing leaving the CC? I replaced the stock hood rain guard with the Heat Extractor bracket, and light blue smoke is constantly coming out of it. LME says, " That's normal (?).
Anyway, this LME motor has more clearance than the OEM, so it makes sense that it would pass more fluid. It does not consume oil, though.
The MM Catch Can was my very first mod on my car. Had exactly 4000 miles (7K Kilometers) on her. And I posted pics of all the oil on the bricks and charger veins, it was unbelievable. After about 15-20,000 miles, I had to pull the lid again. And Voila,..... none. The MM Catch can had done a great job for me. I ordered it just because I wanted an open system under boost. As for the smoke. Here in Thailand. I don't run the rain guard often. It hasn't rained for months. During rainy season only will I run it. I've never seen Smoke.
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
Old 01-20-2026, 11:05 AM   #32
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Bangkok_ZL1 View Post
The MM Catch Can. I've never seen Smoke.
Curious. Light smoke comes out of my rain guard minutes after cranking it, but the oil level stays the same. It doesn't consume any engine oil. We've popped Eddie's lid numerous times, and it always looks fine.
It hasn't used any coolant since the head gasket was replaced.
I would like to solve this mystery.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 01-22-2026, 08:13 PM   #33
Bangkok_ZL1
sounds like a job for a gopro and and a light and see what you can detect.
Old 01-23-2026, 05:05 PM   #34
JSH
JSH's Avatar
Drives: '20 ZLE
The saga, not surprisingly, continues.
MM now says, "you can't run a pcv can (wild kit per title) like that for sure related to the mess out of the breather.
Change the internal to the race 3" here
https://www.mightymousesolutions.com...yclone-upgrade
Unless you need more than 1500hp of capacity in which case i suggest our xl size race can + clamp which is good to 2k
I also strongly suggest venting from the front of the covers. Is this a race car?"
Update:
"The way it's hooked up with the center you have now for PCV only one valve cover was venting the one that was ran into the old exit port does nothing:"
Mine has been set up wrong from day one.
I'll buy the 3" internals, move the bungs up, and shorten the lines. LME put the bungs on the rears, but MM says don't.
This work was done by the now infamous Shop #1 I focused another thread on. Fakes.
2020 ZL1LE A10.
Old 01-24-2026, 08:48 AM   #35
JSH
JSH's Avatar
Drives: '20 ZLE
In summary, the infamous Shop #1 sold me the setup in the first image which should have been the second image. And based on mighty mouse's comments yesterday, this error was the likely cause of me pushing out my rear main seal.
I have yet to determine if one can distinguish between the 2 cans just by looking at them from the outside. Because MM is sending me the race can internals which also fit in the wild can.
2020 ZL1LE A10.
Old 01-24-2026, 11:19 AM   #36
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Something sounds screwy. You should be able to use a Wild can with the -12 line to the valve cover without issue, just like Josh's setup
Mods being installed-
Old 01-24-2026, 12:59 PM   #37
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
The second picture isn't PCV that's CCV. A glorified breather. The first picture The red fitting will be a PCV Valve. Not just a bung.
Old 01-24-2026, 04:11 PM   #38
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Look at my build thread and you will see a crap load of oil soaked under my blower lid. Found out out after I changed the valve cover I didn't get baffled valve covers like how the factory valve covers work so oil was be sent everywhere. I ended up getting properly baffled valve coves and have not had a drop of oil in my blower since.
Post #219
https://www.camaro6.com/forums/showthread.php?t=611982
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 01-24-2026, 06:02 PM   #39
JSH
JSH's Avatar
Drives: '20 ZLE
The first is what I have, but the second is what I needed. Rather than having two lines flowing vapor to the can, I have only one line because the other line pushes vapor against the pcv.
Two flowing lines will be much less messy for me than a breather. My engine has a lot of ring gap compared to OEM. Top ring gap is .023", 2nd ring gap is .025"
2020 ZL1LE A10.
