#29 | |
Moderator
#30 | |
NYTMARE23
Drives: Black 2023 ZL1 A10 Join Date: Oct 2022
2023 A10 ZL1 "NYTMARE"
#31 |
My car wanted 3% more fuel going from the standard rotofab with 95mm tb to the big gulp with 103...This is on a Whipple setup that has a 112mm snout with a mild 10-11psi of boost. On a PD car, anytime you can reduce intake restriction you will gain more power through efficiency. But you have to reduce the restriction all the way from the filter to the blower snout. It doesn't do much good to install a bigger intake on a stock blower snout / 87mm tb setup.
That being said I have run both dry and oiled filters. I like the dry filters...it's just a preference. In the past I have seen transmissions get burned up from oil getting on the maf and skewing air flow data which throws off the torque calculations for transmission shift pressures. This was more of a thing back with gen 3 and 4 LS trucks for some reason. Either way you just have to make sure the filter is not over oiled is all.
#32 | |
Moderator
Yeah I had an ‘04 GTO new back in the day and those Gen 3 MAF sensors were different than the Gen 5 stuff…that sensing element was 100% exposed. These modern MAF sensors all tuck the actual sensing element into a “cartridge” housing so I suspect that’s why they’re much more resistant to an over-oiled filter. Just a guess but seems to be the case. My JLT was WAY over-oiled to the point where I was like “WTF!” but it just didn’t matter during our hub dyno session. So if a filter is oiled properly, it should read just like a dry filter in terms of MAF accuracy.
#33 | |
Moderator
#34 |
![]() Drives: Chevy Camaro ZL11LE Join Date: Jan 2026
KISS.
A. Is a MAF sensor designed to work with a film of oil on it. Answer - No B. Is there a possibility that oil from an improperly oiled filter will end up on the MAF - Yes C. A + B just add together is the answer. Wether or not it happens depends on too many variables for even AI to predict. There is no myth to be debunked when there are documented cases of this happening. Last edited by djctoto; 01-10-2026 at 10:44 AM. Reason: Typo |
#35 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I think the point is that the MAF element is encased in a Gen V engine. It will not be affected by oil.
Run what you like, oiled or dry. It is inconsequential.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#36 | |
NYTMARE23
#37 |
Impossible for the MAF to be fully encased it must be exposed to the airflow to function and is therefore also exposed to any oil that may be present in the air.
#38 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#39 |
fo'shizZL1
Ok, AI engineer literal guy. You are 100% literally correct. You win. I have to go re-oil my filter now.
#40 |
The trade off then appears to be go with an oil filter with even a remote chance that it could screw up your MAF sensor which directly controls AFR's to gain whatever negligible improvement there may be in CFM air flow compared to dry filter where there is no chance of this happening (aside from getting dirty which will happen in either case) or go with a dry filter thereby eliminating the possibility of the critical MAF sensor producing erroneous results.
Don't get me wrong I've used both in the past but I now subscribe to a more simple approach of avoiding any potential problems if it's easy to do so. Sorry if I alarmed any of the oil filter favorites. But don't worry about it a HP or two is worth it compared to not having to even consider the chance that it could cause an issue, who knows. I'm out of this sillyness. Take up the discussion with Mishimoto, but what do they know. Key Considerations Maintenance: Oiled filters must be cleaned and re-oiled at intervals, as the oil layer is crucial for filtration; an over-oiled filter can potentially harm the Mass Airflow (MAF) sensor, says Mishimoto. |
#41 | |
#42 | |
For those high HP applications with folks willing to properly maintain an oil filter it can be the the way to go. For those who may not a dry filter may be the right choice. But to imply that an oil filter is foolproof in all cases is just misleading. |
