#29 | |
Your car's success is a single data point, and it's equally possible that you got luckier than some others, you can't draw any conclusions from this either way.
#30 |
I started this thread to discuss both good and bad shops in the context of my recent experiences with a good one turned bad. I did not start this thread to discuss seemingly inevitable Hennessey controversies. If you feel like criticizing Hennessey, you can just start your own thread, and I promise not to participate. Thanks.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#31 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Good luck on your build and I'm sure no matter the shop you pick, it they are reputable and you have a good feeling about the shop having your car, you'll be fine!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#32 |
Imo when you build enough cars there are going to be some negative experiences. It doesn't mean the shop is necessarily bad. A lot of people these days suffer from entitlement and if they pay someone money for a service, they expect all of their neat ideas to be entertained. The best way to avoid this is to only offer specific packages and do not install customer supplied parts. That is where most problems occur. Back in the 80's, 90's, 00's you never heard anything bad about the OG Lingenfelter in Decatur, IN. And that is because they only offered a few high dollar packages for specific cars. The only knock you ever heard about them was, they were expensive for what you get. But people often overlook longevity and reliability for short term power numbers. And then they are mad when their shit is blown up because the internet said it should have lived 300000k miles making 1200whp on 25psi with 93 octane. His uncles, brothers, cousin setup been that way for 20 years.
#33 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Other local, smaller shops will still do what the customer wants with customer-supplied parts or tuning customer-built cars. They fill a certain niche that is necessary. Those shops also probably get more negative reviews for all of the reasons you mention. They also could just be worse at what they do because they are just a small upstart or whatever. I think the moral of the story is: if you are going to a shop, choose a big name that is respected in the industry and expect to pay a sizeable chunk of money, but then enjoy your car worry-free. The problem with that is if you already have a build from somewhere else. Some of these shops won't touch the car unless they deconstruct it and build it to their liking. Then you are out of pocket a LOT of money at that point.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#34 | |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#35 | |
I'm mainly referring to labor errors rather than parts failures. The more times you turn a wrench, the greater the likelihood of mistakes. I told LME about the head gasket, but didn't expect them to say anything and they didn't. Jason and I agree the tune was likely too aggressive. Shop #1 did not supply my failed intercooler tank, but they made zero effort to fix or replace it. I texted the shop that supplied it, but they didn't reply. The header welds that failed are Kooks' problem, and they basically said yeah it can happen as a result of too much grinding. I get it. With all of the above said, my car is back together and should dyno on a moderate race gas tune this week.
2020 ZL1LE A10.
#36 | |
#37 |
In terms of competent shops, does anyone here know Florida High Performance? Tuner Derek Dunbar seemingly posts daily about the performance results of another car of theirs
2020 ZL1LE A10.
#38 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#39 |
Do you have any idea what their hourly rates are? They run $200-220 here.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 09-29-2025 at 04:57 PM. |
#40 |
No idea, just going off the Corvette forum posts when members inquired about having work done there. If I didn't have Vengeance Racing less than 2 hours away from me, I would travel 8 hours to FHP.
#41 |
Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
After I left for the states for a year. I came back and drove my car around the corner to a local shop for an oil change... cause it's been a year and I didn't want to drive it 500 miles home on oil that had been in the car over a year. While waiting I noticed the guy tightening the new filter on with a wrench and using muscle. I came out screaming, but it was too late. ever since I've got a small oil leak on any new oil filter always. I'm sure he screwed something up. That's why I'd rather do it myself, even if I have to learn some new things. It's hard to trust anybody. I trust the guys here on the forum way before I trust these local guys....
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
#42 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
![]() However, as you had a good experience turn bad, I too am marveled by your good experience with Hennessey as I am from the Houston Area and for decades our shop was one to fix such FauxPas from said shop. As for the numbers they claim, its the many hundreds of Trucks & SUVs getting the floor mats and stickers at dealerships with a snazzy exhaust and a tune to make burble just a little bit more racking up those numbers. I'm sure the big shop will be a huge push and I even had the fun to see his F5 this past weekend while at Hendrick Motorsports purchase for Rick Hendrick's wife as a birthday present. I trust LME with all my engine parts as well, since they seem to have the most talented people I know personally making parts and assembling complete engines in racing. |
