Old 08-19-2025, 04:29 PM   #29
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Guys, please keep politics out of this discussion. Thanks!
Old 08-20-2025, 10:30 AM   #30
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Am I the only one still not happy with the current offerings for theft protection?
Old 08-20-2025, 07:02 PM   #31
SWFLZL1
Drives: 2022 ZL1
No, I’m not real happy with my options either.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 08-20-2025, 07:07 PM   #32
Deacon Blues
Drives: 2024 Camaro 1SS M6
Not at all. I've found since the update on my car that my mobilistics relay has had strange timing. Before I could hit the button on the relay remote then start the car. Now I'm finding I have to push to start, then hit the relay remote within a half second. Not sure if it is a coincidence but it's annoying, and I worry about stalling at an intersection and not being able to get it quickly restarted.
Deacon Blues is offline   Reply With Quote
Old 08-20-2025, 07:20 PM   #33
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
I have not run into that issue.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 08-20-2025, 09:40 PM   #34
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
I haven't noticed any change with my Mobilistics relay timing since the update.
My Camaro Journal
Old 08-21-2025, 12:52 AM   #35
olrocker
olrocker's Avatar
Drives: People crazy with my sexiness
So I was going through the stuff in my parents attic and found the old Chapman air horn siren alarm that was on my dad’s 1985 Buick Regal. He had it installed when it was new, and gave me the car in 1997 for my first car. We removed the siren because it kept going off but that was a wiring issue and not a problem with the siren - these things are LOUD!!!! Didn’t take a picture but I will when I have time to post…..
My question is, I’m trying to think of a way to integrate it into the Camaro’s security system. It runs on simple 12 volts DC, has just a red and black wire, and was triggered in old cars when the door was opened and the interior dome light pin switch in the fender closed and pulled current for the dome lights to turn on, it triggered a relay that spun the siren motor.
Any electrical engineering gurus out there think there’s a way to run a relay off the factory alarm horn signal to a relay connecting the battery to the siren? I know it’s a left field question, just wondering.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023
2024 2SS 6MT coupe
Sharkskin/Light gray
Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers
Gray painted split spoke wheels
Illuminated footwells/illuminated bowtie
olrocker is offline   Reply With Quote
Old 08-21-2025, 08:12 PM   #36
Devstrike
Devstrike's Avatar
Drives: 2020 Camaro LT1
I haven't had this issue since I got my update. I hope it resolves itself soon.
Devstrike is offline   Reply With Quote
Old 08-21-2025, 08:45 PM   #37
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
If you ran the feed for the low pressure fuel pump to a relay with a kill switch. You could swap 87 and 87a. One goes to the fuel pump the other goes to the horn. So active it will default to the horn. It will sound the horn with fuel pump command. Being obnoxiously loud and also no letting the car run. And disengaged it will run normally.
bishopts is online now   Reply With Quote
Old 08-21-2025, 08:54 PM   #38
Deacon Blues
Can you describe your start sequence? Maybe I'm just doing it wrong. Because I used to be able to hit the relay, then push to start. It no longer works that way (for me at least).
Old 08-21-2025, 11:59 PM   #39
DamonZ28
DamonZ28's Avatar
I hold the button on the relay for approximately a second, often while I have the door open and before sitting down. I then drop my keys & relay into my pocket, sit down, and push to start. No issues unless I wait too long in between pushing buttons.
My Camaro Journal
Old 08-22-2025, 02:37 AM   #40
Deacon Blues
Interesting. I've always had to have much closer timing between pushing the relay button and then push to start. I (used to) get in, get situated (buckle up, adjust steering wheel), foot on brake + clutch, push relay and then < 1 second push to start. Anything else would yield a no start or the equivalent of key turned/engine off scenario (accessory mode?).
Now I'm having to get in, brake+clutch, push to start and then hit the relay button.
Old 08-22-2025, 06:14 AM   #41
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
Mine seems to do this intermittently. Every once in a while I'll get in, press the button on the Mobilistics fob, then push in the clutch/press the brakes and press the start button...and nothing. Then while holding the clutch/brakes, I hit the Mobilistics fob button and the car starts up. It almost seems like there is some radio interference when this happens and the Mobilistics fob signal is not getting to the relay. I'm going to try giving the Mobilistics fob a double tap each time I start the car and see if it still occurs. The problem is it only happens once every couple of weeks.
-Ray
Ray3768 is online now   Reply With Quote
Old 08-22-2025, 08:27 AM   #42
Deacon Blues
Thank you guys for your responses on this, I appreciate it! I'll also try the double tap. I know the frequency range isn't far by mobilistics own admission, so I've never tried it without being seated in the car (plus it's a manual so no remote start, I've never had to worry about that).
I'll see what happens and report back .
