#29 |
![]() Drives: camaro Join Date: Oct 2018
I hate to say it but even tho IMO the "drive"/"feel" is different once you swap out the tire compound, that safe feeling the performance all seasons gave me was a decent substitute....Glad your dad is ok, Thats the most important. Sounds like you're already on track to do what's best for you/your wallet. Just curious, who did you take your car to in the Chicagoland area for work?
#30 |
![]() Drives: Zl1 1le Join Date: Apr 2018
#31 |
Well guys there has been an update, car is repairable.... but some things seem way off in the parts list..... for example rear shock at $110 no way that's mag ride..... what you all think?
#32 |
Sarcasm loading --------
Sounds like it is going to be fixed.
Drive the wheels off it.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#33 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Well, that part number is for a KYB gas-a-just shock for an SS without mag ride, so yeah, I'd say you are correct. There might be a few other parts in there that didn't translate properly. The NAPA brake rotor they quoted is at least the correct diameter for a ZL1, though.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#34 |
So cool stuff can be done with AI, it went line by line and spit out the corrected parts
See below: Front Bumper Line 1 (S1): Front Bumper Cover (Remove/Install, Existing) No part number since it’s an existing part being reinstalled. Compatibility: The ZL1 has a unique front bumper cover with aerodynamic enhancements and larger air intakes compared to base Camaro models. As this is the vehicle’s original part, it’s compatible unless damaged beyond repair (not indicated). Hood Line 2: Hood Outside (Blend Refinish) No replacement part; refinishing only. Compatibility: N/A (no part replaced). Line 3: Hood Scoop (Remove/Install, Existing) No part number; existing part. Compatibility: The ZL1 features a functional hood scoop for the supercharger. This is the original part, so it’s compatible. Front Fender Line 4: Right Fender Panel (Remove/Replace, New, Part #84326264) The ZL1 has wider fenders to accommodate its wider track and tires. Part #84326264 is listed as a new OEM part, likely specific to the ZL1 given the estimate context. Compatibility: Probable fit, but verify with Chevrolet parts catalog for ZL1 specificity. Line 5: Right Fender Outside (Refinish Only) No part replaced. Compatibility: N/A. Line 6: Right Add To Edge Fender (Refinish Only) No part replaced. Compatibility: N/A. Line 7: Right Fender Liner (Remove/Install, Existing) No part number; existing part. Compatibility: Compatible as it’s the original ZL1 fender liner. Air Bag System Line 8: Right Front Air Bag Impact Sensor (Remove/Replace, New, Part #13509729) Airbag sensors are typically standardized across Camaro trims but must match the ZL1’s restraint system. Compatibility: Likely compatible; verify with GM parts catalog. Line 9: Right Air Bag Side Curtain Module (Remove/Replace, New, Part #84672544) ZL1 uses side curtain airbags consistent with other Camaros, but part must match coupe configuration. Compatibility: Probable fit; confirm ZL1 coupe compatibility. Line 10: Roof Headliner (Remove/Install) Included with airbag replacement; no part number. Compatibility: N/A. Line 11: Left Air Bag Side Curtain Module (Remove/Replace, New, Part #84672543) Same as above for left side. Compatibility: Probable fit; confirm ZL1 coupe compatibility. Line 12: Air Bag Module - Passenger Seat (Remove/Replace, New, Part #84019645) Seat airbag module specific to ZL1’s sport seats. Compatibility: Likely compatible; verify with GM for ZL1 seat design. Line 13: Right Front Seat Assembly (Remove/Install) No part replaced. Compatibility: N/A. Line 14: Right Front Air Bag Side Impact Sensor (Remove/Replace, New, Part #13583355) Side impact sensor; should match ZL1’s system. Compatibility: Likely compatible; verify with GM. Line 15: Right Front Door Trim Panel (Remove/Install) No part replaced. Compatibility: N/A. Line 16: Right Rear Air Bag Side Impact Sensor (Remove/Replace, New, Part #13509729) Same part number as Line 8; rear sensor. Compatibility: Likely compatible; verify with GM. Wheel Line 17: Rear Alloy Wheel (Remove/Replace, Remanufactured, Part #ALYGR097U79) ZL1 uses 20-inch forged aluminum wheels (10-spoke design). This is a remanufactured part, not OEM. Compatibility: Uncertain; verify size (20x10 rear), offset, and ZL1 compatibility with supplier. Steering Wheel / Column Line 18: Steering Wheel (Remove/Replace, New, Part #84791303) ZL1 has a flat-bottom steering wheel with specific controls (e.g., heated option listed). Compatibility: Likely compatible if it includes ZL1 features; verify with GM. Line 19: Steering Column Assembly (Remove/Replace, New, Part #84961918) Must match ZL1’s manual transmission and electronic controls. Compatibility: Probable fit; confirm with GM parts catalog. Engine / Body Under Covers Line 20: Underbody Front Air Deflector (Remove/Replace, New, Part #84084634) ZL1 has unique underbody aerodynamics. Compatibility: Likely compatible; verify ZL1-specific design. Front Seat Line 21: Passenger Side Seat Back Cover (Remove/Replace, New, Part #84862652) ZL1 has Recaro performance seats (leather, heated). Compatibility: Probable fit; confirm it matches ZL1 Recaro seat specs. Seat Belts Line 22: Right Front Seat Belt Assembly (Remove/Replace, New, Part #84496830) Must fit ZL1’s bucket seats and pretensioner system. Compatibility: Likely compatible; verify with GM. Line 23: Left Front Seat Belt Assembly (Remove/Replace, New, Part #84496892) Same as above for left side. Compatibility: Likely compatible; verify with GM. Line 24 (S1): Right Front Seat Belt Bolt (Remove/Replace, New, Part #11519383) Standard bolt; should fit ZL1 seat mounting. Compatibility: Compatible (generic fastener). Line 25 (S1): Left Front Seat Belt Bolt (Remove/Replace, New, Part #11519383) Same as above. Compatibility: Compatible. Line 26: Right Front Seat Belt Pretensioner (Remove/Replace, New, Part #19333451) ZL1-specific pretensioner for safety system. Compatibility: Likely compatible; verify with GM. Line 27: Left Front Seat Belt Pretensioner (Remove/Replace, New, Part #19333450) Same as above for left side. Compatibility: Likely compatible; verify with GM. Line 28: Left Front Seat Assembly (Remove/Install) No part replaced. Compatibility: N/A. Line 29 (S1): Right Front Seat Belt Buckle (Remove/Replace, New, Part #19366528) Must match ZL1 seat design. Compatibility: Likely compatible; verify with GM. Line 30 (S1): Left Front Seat Belt Buckle (Remove/Replace, New, Part #19366527) Same as above for left side. Compatibility: Likely compatible; verify with GM. Front Door Line 31: Right Front Door Outside (Blend) No part replaced. Compatibility: N/A. Line 32: Right Front Rear View Mirror (Remove/Install, Existing) ZL1 has specific mirror design with memory function. Compatibility: Compatible as it’s the original part. Line 33: Right Front Outer Door Belt Moulding (Remove/Install, Existing) Compatibility: Compatible (original part). Line 34: Right Front Outer Door Handle (Remove/Install, Existing) Compatibility: Compatible (original part). Roof Line 35 (S1): Roof Headliner (Remove/Replace, New, Part #87839031) Must fit ZL1 coupe with head-up display and airbag modules. Compatibility: Likely compatible; verify with GM for ZL1 trim. Side Body Line 36 (S1): Right Quarter Panel Outside (Refinish Only) No part replaced. Compatibility: N/A. Line 37 (S1): Right Roof Rail (Blend) No part replaced. Compatibility: N/A. Line 38: Right Side Body Panel Assembly (Repair) No part replaced. Compatibility: N/A. Line 39 (S1): Right Rocker Moulding (Remove/Install, Existing) ZL1 has unique rocker panels. Compatibility: Compatible (original part). Quarter Glass Line 40 (S1): Right Quarter Glass (Remove/Install, Existing) Compatibility: Compatible (original part). Luggage Lid Line 41 (S1): Luggage Lid Spoiler (Remove/Install, Existing) ZL1 has a standard rear spoiler. Compatibility: Compatible (original part). Rear Suspension Line 42 (S1): Right Rear Suspension One Side (Overhaul, Existing) No part replaced; overhaul of existing components. Compatibility: N/A. Line 44: Right Rear Suspension Brake Rotor (Remove/Replace, New, Part #248880712) NAPA part; ZL1 uses high-performance Brembo brakes (14.4-inch rear rotors). Compatibility: Uncertain; verify size and Brembo compatibility. Line 45 (S1): Right Rear Suspension Shock Absorber (Remove/Replace, Aftermarket New, Part #3440100) ZL1 uses Magnetic Ride Control shocks. Compatibility: Unlikely compatible; aftermarket part may not match ZL1’s adaptive suspension. Line 46: Right Rear Suspension Coil Spring (Remove/Replace) No part number listed (incomplete entry). Compatibility: Unknown; verify ZL1 spring rate and part number. Line 47 (S1): Right Upper Rear Suspension Trailing Arm (Remove/Replace, New, Part #84826388) ZL1 has performance-tuned suspension. Compatibility: Likely compatible; verify with GM. Line 48 (S1): Right Lower Rear Suspension Trailing Arm (Remove/Replace, New, Part #86804916) Compatibility: Likely compatible; verify with GM. Line 49 (S1): Right Upper Rear Suspension Control Arm (Remove/Replace, New, Part #84826391) Compatibility: Likely compatible; verify with GM. Line 50 (S1): Right Lower Rear Suspension Control Arm (Remove/Replace, New, Part #84382227) Compatibility: Likely compatible; verify with GM. Line 51 (S1): Right Lower Rear Suspension Cover (Remove/Replace, New, Part #22823593) Compatibility: Likely compatible; verify with GM. Line 52 (S1): Right Rear Suspension Link (Remove/Replace, New, Part #86804922) Compatibility: Likely compatible; verify with GM. Line 53: Rear Suspension Support (Remove/Replace) No part number (incomplete entry). Compatibility: Unknown; verify part number. Rear Drive Axle Line 54: Right Rear Drive Axle Shaft (Remove/Replace) No part number (incomplete entry). Compatibility: Unknown; verify ZL1 axle specs. Rear Lamps Line 55: Right Rear Combination Lamp (Remove/Install) No part number; existing part. Compatibility: Compatible (original ZL1 taillight). Line 56: Right Rear Body Side Trim Panel (Remove/Install) No part replaced. Compatibility: N/A. Rear Bumper Line 57 (S1): Rear Bumper Cover (Remove/Install, Existing) ZL1 has a unique rear bumper with diffuser. Compatibility: Compatible (original part). Tires Line 69: Goodyear Eagle F1 Supercar 3 305/30ZR20Y (Remove/Replace, Aftermarket New, Part #797789523) ZL1 stock rear tire size is 305/30ZR20. Compatibility: Compatible; matches ZL1 rear tire specs. Summary of Compatibility Confirmed Compatible: Most existing parts being reinstalled (e.g., bumper cover, fender liner, spoiler) and generic fasteners (e.g., seat belt bolts #11519383). Tire (#797789523) matches ZL1 specs. Likely Compatible (Verify with GM): Most new OEM parts (e.g., fender #84326264, airbag components, seat belts, suspension arms) appear ZL1-specific based on context, but part numbers should be cross-checked in a GM catalog for exact trim fitment. Uncertain (Verification Needed): Rear Alloy Wheel (#ALYGR097U79): Remanufactured; confirm size and ZL1 compatibility. Rear Brake Rotor (#248880712): NAPA part; verify Brembo specs. Rear Shock Absorber (#3440100): Aftermarket; unlikely to match ZL1 Magnetic Ride Control. Incomplete Entries: Lines 46, 53, 54 lack part numbers; cannot assess without further details. Recommendations For repairs to proceed accurately on the 2019 Camaro ZL1: Verify OEM Parts: Cross-reference all GM part numbers (e.g., #84326264, #84672544) with a Chevrolet parts catalog or dealer to ensure ZL1 trim compatibility. Check Non-OEM Parts: Confirm remanufactured wheel (#ALYGR097U79), NAPA rotor (#248880712), and aftermarket shock (#3440100) match ZL1 specs (size, performance rating). Complete Missing Data: Obtain part numbers for Lines 46, 53, and 54 to assess fitment. Contact Progressive: If parts don’t match ZL1 requirements (e.g., shock absorber), request adjustments per their lifetime guarantee policy. If you need further assistance or specific part lookups, I can offer to search with your permission, though I’ll need to rely on external tools for that. Let me know how to proceed! now find all the parts that need to be changed to zl1 parts 15 web pages To determine which parts in the insurance estimate need to be changed to ensure they are specifically compatible with the 2019 Chevrolet Camaro ZL1, I’ll analyze the document and identify parts that are either aftermarket, remanufactured, or lack sufficient detail to confirm ZL1 compatibility. The ZL1 is a high-performance trim with unique components (e.g., Magnetic Ride Control suspension, Brembo brakes, Recaro seats, and aerodynamic body parts), so replacements must match these specifications rather than generic Camaro parts. My previous analysis confirmed most OEM parts are likely ZL1-compatible but require verification. Here, I’ll focus on parts that deviate from OEM ZL1 standards or are questionable, recommending they be swapped for verified ZL1-specific parts. The process involves: Reviewing each replacement part (excluding remove/install of existing parts or refinish-only operations). Identifying non-OEM parts (aftermarket, remanufactured, sublet) or incomplete entries. Highlighting parts where ZL1 specificity is uncertain due to potential trim differences. Suggesting they be replaced with OEM ZL1 parts, verified via GM’s parts catalog. Today is February 28, 2025, so all parts should align with the 2019 ZL1’s factory specs as of that model year. Parts That Need to Be Changed to ZL1-Specific Parts Wheel Line 17: Rear Alloy Wheel (Remanufactured, Part #ALYGR097U79, $355.00) Issue: The ZL1 uses 20x10-inch forged aluminum rear wheels (specific offset and design for its wider track). This is a remanufactured part, not OEM, and lacks confirmation of ZL1 specs (size, offset, weight rating). Change Needed: Replace with OEM ZL1 rear wheel (GM Part #84306745 or equivalent for 20x10 rear, verify fitment for 2019 ZL1). Rear Suspension Line 44: Right Rear Suspension Brake Rotor (New, Part #248880712, $35.71, NAPA) Issue: The ZL1 uses 14.4-inch Brembo rear rotors (6-piston calipers front, 4-piston rear). This NAPA part’s low cost and lack of Brembo branding suggest it’s not ZL1-compatible. Change Needed: Replace with OEM ZL1 rear rotor (GM Part #23343166 or equivalent Brembo rotor for 2019 ZL1). Line 45 (S1): Right Rear Suspension Shock Absorber (Aftermarket New, Part #3440100, $110.41, NAPA) Issue: The ZL1 uses Magnetic Ride Control shocks, a sophisticated adaptive system. This aftermarket NAPA shock is unlikely to match the ZL1’s performance requirements or electronics. Change Needed: Replace with OEM ZL1 rear shock absorber (GM Part #84302138 or equivalent Magnetic Ride Control unit for 2019 ZL1). Line 46: Right Rear Suspension Coil Spring (New, No Part Number Listed) Issue: No part number provided, so compatibility with ZL1’s performance-tuned spring rate is unknown. ZL1 springs are specific to its handling dynamics. Change Needed: Replace with OEM ZL1 rear coil spring (GM Part #84230318 or equivalent, verify for 2019 ZL1). Line 53: Rear Suspension Support (New, No Part Number Listed) Issue: Incomplete entry; no part number or details. The ZL1’s suspension support must handle its high-performance loads. Change Needed: Replace with OEM ZL1 rear suspension support (verify part number via GM catalog, e.g., #84157303 if applicable). Rear Drive Axle Line 54: Right Rear Drive Axle Shaft (New, No Part Number Listed) Issue: No part number; ZL1’s axle shafts are reinforced for 650 hp and specific to its differential (3.73 ratio manual trans). Change Needed: Replace with OEM ZL1 rear axle shaft (GM Part #84594436 or equivalent for 2019 ZL1 manual). Additional Costs & Materials Line 68 (S1): Urethane Glass Kit (Aftermarket New, "Qual Repl Part", $20.00) Issue: Generic aftermarket glass adhesive may not meet ZL1’s structural or safety standards for quarter glass installation (Line 40). Change Needed: Replace with OEM ZL1-approved urethane glass kit (GM Part #19355305 or equivalent adhesive/sealant). Tires Line 69: Goodyear Eagle F1 Supercar 3 305/30ZR20Y (Aftermarket New, Part #797789523, $337.22) Issue: The ZL1 stock rear tire is Goodyear Eagle F1 Supercar 3 305/30ZR20, matching this spec. However, “aftermarket” sourcing raises authenticity concerns (counterfeit risk). The estimate doesn’t confirm it’s the exact ZL1 variant (summer-only, specific compound). Change Needed: Replace with OEM ZL1-spec Goodyear Eagle F1 Supercar 3 tire (GM Part #84207107 or direct from Goodyear with ZL1 certification). Parts That Are Likely Fine But Should Be Verified The following parts are new OEM with GM part numbers, likely ZL1-compatible based on context, but should be cross-checked with a GM parts catalog to ensure exact trim fitment (ZL1 vs. SS or base Camaro): Line 4: Right Fender Panel (#84326264) Line 8: Right Front Air Bag Impact Sensor (#13509729) Line 9: Right Air Bag Side Curtain Module (#84672544) Line 11: Left Air Bag Side Curtain Module (#84672543) Line 12: Air Bag Module - Passenger Seat (#84019645) Line 14: Right Front Air Bag Side Impact Sensor (#13583355) Line 16: Right Rear Air Bag Side Impact Sensor (#13509729) Line 18: Steering Wheel (#84791303) Line 19: Steering Column Assembly (#84961918) Line 20: Underbody Front Air Deflector (#84084634) Line 21: Passenger Side Seat Back Cover (#84862652) Line 22: Right Front Seat Belt Assembly (#84496830) Line 23: Left Front Seat Belt Assembly (#84496892) Line 24-25 (S1): Seat Belt Bolts (#11519383) - Generic fastener, likely fine. Line 26: Right Front Seat Belt Pretensioner (#19333451) Line 27: Left Front Seat Belt Pretensioner (#19333450) Line 29 (S1): Right Front Seat Belt Buckle (#19366528) Line 30 (S1): Left Front Seat Belt Buckle (#19366527) Line 35 (S1): Roof Headliner (#87839031) Line 47 (S1): Right Upper Rear Suspension Trailing Arm (#84826388) Line 48 (S1): Right Lower Rear Suspension Trailing Arm (#86804916) Line 49 (S1): Right Upper Rear Suspension Control Arm (#84826391) Line 50 (S1): Right Lower Rear Suspension Control Arm (#84382227) Line 51 (S1): Right Lower Rear Suspension Cover (#22823593) Line 52 (S1): Right Rear Suspension Link (#86804922) These should be confirmed via GM’s parts system (e.g., using VIN 1G1FJ1R63K0128006) to ensure they aren’t for a different Camaro trim. Summary of Parts to Change Here’s the list of parts that need to be swapped for ZL1-specific OEM equivalents: Rear Alloy Wheel (#ALYGR097U79) → OEM ZL1 wheel (#84306745 or equivalent). Right Rear Suspension Brake Rotor (#248880712) → OEM ZL1 Brembo rotor (#23343166 or equivalent). Right Rear Suspension Shock Absorber (#3440100) → OEM ZL1 Magnetic Ride shock (#84302138 or equivalent). Right Rear Suspension Coil Spring (No #) → OEM ZL1 spring (#84230318 or equivalent). Rear Suspension Support (No #) → OEM ZL1 support (verify #, e.g., #84157303). Right Rear Drive Axle Shaft (No #) → OEM ZL1 axle shaft (#84594436 or equivalent). Urethane Glass Kit ("Qual Repl Part") → OEM ZL1 glass adhesive (#19355305 or equivalent). Goodyear Eagle F1 Supercar 3 Tire (#797789523) → OEM ZL1-spec tire (#84207107 or equivalent). Next Steps Contact Progressive: Request these parts be updated to OEM ZL1 equivalents under their lifetime guarantee, as non-OEM parts may not restore the vehicle to pre-loss condition (per Page 7). Verify with GM Dealer: Use the VIN and GM parts catalog to source exact ZL1 replacements. Update Estimate: Ensure the repair shop (Wheel Inn Body & Motor Works) orders these parts. Let me know if you need help drafting a request to Progressive or further details on sourcing these parts! |
