Old 02-22-2025, 09:00 AM   #29
KamZL1
KamZL1's Avatar
Drives: Z06
After much thought and your guys' feedback, I'm leaning towards a c7 z06. I know some of you guys have had one, or do have one currently so I'm wondering what year did they fix the cooling issues? Also is the low side on these more robust than the Zl1? I plan on building this similar to my zl1 with e/headers, then eventually adding boost with porting/pulleys. Just curious on anything to look out for with these. As always, thanks in advance!
KamZL1 is offline   Reply With Quote
Old 02-22-2025, 11:29 AM   #30
LuckZL1
Drives: Camaro ZL1
The 2019 C7Z06 is when they added some ZR1 upgrades.
https://www.corvetteforum.com/forums...post1601398284
I had a 2019 C7Z06 and it was definitely a fun car. The only thing I miss is being able to buy an Akrapovic Titanium exhaust. Other than that, I feel that the Corvette didn't give as much confidence as a stock manual transmission (I switched to MGW which was amazing), and adding power. The weight of the car and width of tires made the car wobble a lot on even small cracks in the road. The power adders really made the car tail happy as well even with Toyo R888R's.
LuckZL1 is offline   Reply With Quote
Old 02-22-2025, 05:31 PM   #31
jfkheat
jfkheat
jfkheat's Avatar
Drives: 2023 ZL1, 2023 Challenger Hellcat
2 1/2 months ago I bought a new 2023 Challenger Hellcat with 290 miles on it. I am a big guy so my ZL1 is a bit tight for me. The Hellcat is a lot more comfortable and rides better. The prices of these have dropped a lot in the last 2 years since they stopped building them. There are still quite a few new Hellcats sitting on dealer lots throughout the country. If you spend some time looking around you can find them for $15-20k below MSRP. MSRP on mine was $86,135. After all fees, taxes and delivery cost, I paid $65,891. Dodge advertises them to have 717 hp at 6000 rpm but they actually have 745 at 6200 rpm.
jfkheat is offline   Reply With Quote
Old 02-22-2025, 07:22 PM   #32
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
I know the HC has a lot more power, but they also have a lot of traction issues on the street. Which car do you feel is quicker on the street with just sticky street tires, the HC or ZL1 ? I've heard the HC isn't really much quicker than a Scat Pack on the street due to their traction issues, light to light, 1/8th mile type of stuff.
White1SS is offline   Reply With Quote
Old 02-22-2025, 07:52 PM   #33
jfkheat
jfkheat
jfkheat's Avatar
With the factory tires, neither car will hook up very well in a drag race. The Hellcat handles better at high speeds. At around 140 or so mph the ZL1 starts getting lite in the front. I wouldn't feel save driving it much faster than that. I've had the Hellcat up to 149 and it still felt pretty stable. I feel like it will handle pretty good at 170 to 175. The extra 5-600 pounds just makes it feel safer. I haven't put but 10 or so miles on the ZL1 since I bought the Challenger.
Old 02-22-2025, 10:00 PM   #34
White1SS
White1SS's Avatar
Wow I've never heard that about a 6th gen Camaro, never mind a ZL1. I would have expected the exact opposite of that. I've never had my SS over 130, even with the factory run flats it felt pretty stable though. It seems you prefer the overall package of a Hellcat over the ZL1 ?
Old 02-22-2025, 11:04 PM   #35
I had my 2SS up in this speed range, and it was rock solid, I didn't feel any lightness in the front. It's unlikely that the ZL1 would be worse than my modded 2SS that has a 1LE front splitter with side skirts and a simple diffuser, but sits higher off the ground.
Granted, the ZL1 1LE has more front aero, but it had no problem doing 160-170 on the Nürburgring when Bill Wise set the Camaro record.
Old 02-22-2025, 11:45 PM   #36
Camfab
Drives: ‘23 ZL1-1LE
I am so confused by your post, what are you trying to get across? The Corvette wasn’t as confident as a manual transmission and adding power?
Camfab is offline   Reply With Quote
Old 02-22-2025, 11:48 PM   #37
jfkheat
jfkheat
jfkheat's Avatar
It may be the crappy summer only factory tires that made the ZL1 feel the way it did. I did take the Camaro on a nice mountain trip on the Blue Ridge Parkway last year and had a blast with it. The Camaro definitely out handles the Challenger on the winding mountain roads.
Old 02-22-2025, 11:53 PM   #38
LuckZL1
Drives: Camaro ZL1
Sorry I was all over the place but I feel like OP most likely already looked into the C7 Z06 knowing that it is a 7 speed manual and I wanted to get that link to OP to see which parts were added. I tried to answer the other questions in that quick summary but going from 6-Speed to 7-Speed manual and being consistently fast in shifting could take a bit of getting used to.
The Corvette’s stock shifter also has a longer throw and MGW luckily made a short throw shifter for it to make it better. On top of that, adding more power to a light car can make driving a lot harder.
The main point is that the driving characteristics of the Z06 and the ZL1 is different even though they have the same power plant. I feel more confident in the ZL1 and having been apart of the corvette forums in the past, I know a lot more people feel the same way.
Old 02-23-2025, 08:34 AM   #39
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
Tune with HP Tuners to prevent theft? I was playing around with these settings this past summer and noticed it appears I can limit the rpm of the car with these settings. My idea, it that truly what I remember. I could flash a tune where these numbers basically won't left the car run, or go over 700 rpm say for example. Preventing my car from being driven away? Any thoughts on this?
Basically the idea would be to flash my current/really tune when I go drive the car and flash this alternate tune when I don't want the car to be driven?
Thanks
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 02-23-2025, 08:39 AM   #40
2023_ZL1-AUTO
I had my 2SS up in this speed range, and it was rock solid....
I had mine up to 162mph on the freeway during a remote tune session with Andrew at CSP Racing. It was solid as a rock! It felt so smooth it was like I was driving on a glass surface. I did have Nitto R555R2's on it at the time. But man was it smooth.
Old 02-23-2025, 11:29 AM   #41
Thanks
The reasonably expected calibration write count for the ECM flash storage is less than 10 for the lifetime of the vehicle. If you get your car tuned, then maybe 50 total, again, throughout the car's entire lifetime. Knowing that and how GM likes to pinch their pennies, I'd be surprised if these chips were able to withstand 1-2 tune writes per day for long.
Old 02-23-2025, 11:37 AM   #42
Camfab
Drives: ‘23 ZL1-1LE
Got it, makes sense and yes MGW makes great products.
