#29 |
The same thing happens with a pre-meth tune, which eliminates that variable. It might be the way the RR bites and spins, or the tire might be turning in the wheel.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#30 |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Did you check the bolts on back of the trans? VSS graph smooth when it happens?
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#31 |
I'm not 100% sure. Which bolts? I don't see VSS on my logs. If it's not there, I'll add it.
2020 ZL1LE A10.
#32 | |
The bolts are on the rear cover around the output of the trans.
#33 |
2020 ZL1LE A10.
#34 | |
2020 ZL1LE A10.
